F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 62K miles F30, BMW dealer says no need for transmission fluid replacement
GetBMWParts
      03-26-2024, 03:54 PM   #1
micharlie
Drives: BMW 328i
Is that true?
He said I quote
“We do not change/flush transmission fluid unless doing a transmission repair - the fluid is lifetime”
      03-26-2024, 04:03 PM   #2
MidtownMike
Drives: BMW F30 LCI 320i M-Sport Shado
It is indeed the official BMW story.
However, ZF, the manufacturer of the transmission says the fluid (and filter) needs to be replaced every 100k km. ZF sells service kits which include fluid and filter.
      03-26-2024, 04:16 PM   #3
_ObiJon
_ObiJon's Avatar
Drives: 2015 428i xDrive
TX55248.50
      03-26-2024, 04:25 PM   #4
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Same here. By the way... ZF increased the interval from 60k miles (100k km) to 100k miles.
Taking both stances into account (manufacturer and retailer), whats that tell you?
      03-26-2024, 05:14 PM   #5
MidtownMike
BMW is heavily dependent on the lease market (at least here in Europe). To keep the lease "affordable" and competitive, the maintenance cost needs to remain low. That is why the prescribed oil change intervals are ridiculously long and no transmission oil change factored in (blatantly ignoring the transmission manufacturer's recommendation).
By the time the negative effects start to show and shit breaks down, the car is out of warranty, so not BMW's problem.
Billfitz8243.00
      03-26-2024, 07:33 PM   #6
eff32fl
eff32fl's Avatar
1052
Drives: 2019 440i M Sport THP MPPSK
When did this happen? Do you have a link by chance? I'm nearing 60k miles so want to get my tranny serviced as soon as it's recommended. I'm not listening to BMW and will trust the manufacturer lol.
EDIT: Looks like it happened 7/19/2021. It's now recommended at 150k KM or 93k miles. It says with high temperature or load you can do it sooner.
https://aftermarket.zf.com/remotemed...fluid-8-it.pdf
      03-27-2024, 07:35 AM   #7
RS Hill
Drives: 2019 F36 GC
In my opinion for what it's worth, I've seen a lot of these long life fluids go bad for the consumer as the consumer follows the recommendations from the manufacturer. My own personal thoughts are to stick servicing the Trans at the 30 to 35k mark.
      03-27-2024, 09:05 AM   #8
danb1979
Idiotic lifter of heavy stones...
danb1979's Avatar
1891
Drives: 2015 F31 325D M Sport touring
Don't go with what BMW state; go with what ZF state
They did state 60-80k miles is the time to do the fluid & filter service
BMW state 'sealed for life' which in their language means c100k miles, as that's what they feel the average ownership of a BMW is...
Get it done now and you'll more than likely not need to get it done again (unless you plan to run the car into the ground)
My car: 2015 F31 325D M Sport Touring in Glacier Metallic Silver - Keeping it OEM 'Plus'
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298
      03-27-2024, 09:18 AM   #9
Tommo3
Drives: 2018 F31 318d
They state 60-80k miles is the time to do the fluid & filter service
You really should read the thread before commenting. It has been pointed out that ZF state 150000 kms and then you come along and contradict that.
I have 110000 miles on mine and will leave well alone as BMW tells me to.
      03-27-2024, 09:27 AM   #10
danb1979
danb1979's Avatar
1891
Oh do piss off; you bore on every thread like this... You're a knob when it comes to oil threads and now ZF threads
The info I've posted is there to be found on Google
ZF state 60-80k miles; they may have changed that, but it's still only 92k miles
One of MANY posts that state this: https://www.pscautocentre.co.uk/prod...0the%20soonest.
FCP even state 50k miles here: https://blog.fcpeuro.com/how-to-chan...%20and%20model.
So no idea where you get your completely wrong 150k km from...
Stick to playing toy soldiers in France will you...
BMW don't always know best you deluded cockwomble - you really are up BMWs arse aren't you?!
      03-27-2024, 12:00 PM   #11
monster6a2
monster6a2's Avatar
Drives: f30 335i xdrive
Originally Posted by micharlie View Post
Is that true?
He said I quote
My dad owned a car repair shop for 12 years of his life. His transmission specialist told him than you do one of 2 things with transmission fluid changes, you either change it from brand new on intervals, or never change it. If your at 60k, I wouldn’t change. Changing it will diminish the lifespan of your transmission significantly.
Tommo355.00
      03-27-2024, 01:07 PM   #12
MidtownMike
Dude what?
      03-27-2024, 01:12 PM   #13
monster6a2
monster6a2's Avatar
Originally Posted by MidtownMike View Post
Dude what?
Yeah. Ik it sounds crazy but I guess after you’ve had the same fluids in a transmission for an extended period of time, they build up a detergent so when u change the fluids after not changing the fluids for the majority of the transmissions life, it’ll cause more friction and basically reduce your transmission lifespan. Ik it sounds crazy and counterintuitive but go ask someone at a transmission shop and I bet they will same the same thing
Pauloxxi339.00
      03-27-2024, 02:28 PM   #14
MidtownMike
You talk like he's at 600k miles, but 60k is a normal interval to refresh trans fluid.
The way you put it, it sounds like a prudent owner should have refreshed the fluid six times already by now, and that 60k is wayyy too late.
By the way, I never heard about detergent (?) buildup. In an old transmission there can however be sludge buildup that prevents seals and gaskets from leaking. In those cases, a fluid refresh can initiate some leaking, and seals should be replaced. However, at 60k that should not be a thing.
Why would ZF recommend an oil change at 60k (now 90k) if it destroys the transmission? Hoping to sell more transmissions at the expense of their reputation?
danb19791891.00
      03-27-2024, 02:30 PM   #15
danb1979
danb1979's Avatar
1891
So the autobox & ZF specialist in my hometown; that's been around since the dark ages, and does autobox services/repairs/replacements etc is wrong?!
Ok...
      03-27-2024, 03:43 PM   #16
monster6a2
monster6a2's Avatar
Ok...
Idk, if you explained what I’m explaining to him then I bet he would agree in some level
      03-27-2024, 03:58 PM   #17
im_an_alien
im_an_alien's Avatar
1129
Drives: 2016 340i
I agree with this, either do it from the start or leave it alone. Plenty of previously faultless transmissions seem to develop issues shortly after a fluid change...
      03-27-2024, 04:04 PM   #18
MidtownMike
From what mileage is "from the start" for you then? If it's not 60k, what then?
      03-27-2024, 04:17 PM   #19
im_an_alien
1129
Drives: 2016 340i
Probably sooner than called for, like 30k miles. The earlier the better if you're gonna go this route.
      03-27-2024, 04:20 PM   #20
danb1979
danb1979's Avatar
1891
I've had ZF boxes in my E39s serviced with zero issues afterwards; ones currently on 176k miles now (I had the fluid changes when I owned it at 130k miles); the 2nd one was changed when I owned it at 80k miles, it's now on c150k IIRC
My 2002 Jap import E39 touring was serviced at 82k miles, I sold it at 99k miles and its on 120k miles now, zero issues and my last E39, another Jap import E39 540i Sport saloon was serviced at 52k miles and 21 years old; the oil was a mess. The box was very much better after the service and its still smooth as silk now
I've also had the ZF6 boxes serviced in an E65 and F01 and both are still doing very well now and do a lot of miles from what I know
My current F31 is on 100k miles and I'll be getting in to be serviced when I've got 5mins to think...
ZF would not recommend the service of their boxes if they were to have issues; neither would someone like Grant at Automatic Transmissions, Preston, who as Ive said, has been around since the dark ages...
I'll go with what those folk say rather then Jim-Bob on the forums 'cos Daddy says so'...
rlesko232.50
      03-27-2024, 04:48 PM   #21
sspade
sspade's Avatar
Drives: F30
Directly from ZF:
Lifetime in most cases (maintenance free) but a good idea to change at 90k miles under harsh conditions or unknown history of use.
Read it and weep!
      03-27-2024, 05:12 PM   #22
im_an_alien
1129
Drives: 2016 340i
ZF "recommends" fluid change, and only under certain conditions, otherwise they say it's maintenance free... it's right there, clear as mud.
Recommend isn't the same as require..
f30post
