F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > new bosch injectors Teflon seal not compressed?
Extreme Powerhouse
      05-28-2023, 12:21 PM   #1
tvlbott
Drives: 2017 BMW 440i M
Shouldn’t these have a metal piece on here that keeps them compressed?
Do I need to compress them or just apply some assembly oil and install?
Was told I did not need the tool kit for brand new injectors
      05-28-2023, 12:34 PM   #2
Dagstar
Drives: 2014 F31 M Sport
You'll need decoupling elements. They're metal rings that snap in place, no tool needed. Should be part #13537577649
      05-28-2023, 12:37 PM   #3
tvlbott
Originally Posted by Dagstar View Post
You'll need decoupling elements. They're rings that snap in place. Should be part #13537577649
Both that and the Teflon seals are pre installed. I just thought the Teflon seals had a metal piece that keeps them compressed. But it doesn’t appear so.
Just trying to figure out if I can install them
      05-28-2023, 07:41 PM   #4
SuperLomi
Drives: 2013 335i M-Sport
Your picture does not show the decoupling element installed.
      05-28-2023, 07:50 PM   #5
tvlbott
Well my old ones didn’t have one on them so idk. I installed them I guess I’ll keep on eye on them.
Also ista didn’t mention them in the process so idk
      03-25-2024, 08:26 AM   #6
Sato
Drives: M135i
Hi, did you compressed seal somehow before install? My Bosch injector just arrived and it looks exactly the same as yours. Not sure what to do next. Zip ties method seems doable as describe here: https://www.thedrive.com/guides-and-...r-seal-service but is it necessary?
      03-26-2024, 12:18 PM   #7
E36M3
Drives: 97 M3, '14 335i, '12 X3 35i
With new injectors you don’t need to resize the Teflon seal. That is for reusing existing injectors and the Teflon seal is a mandatory replacement item every time you reuse an injector and must be resized once it is installed. I’ve done both. As has been pointed out you must install the decoupling element on the new injector. Your original injector you removed had it.
      03-27-2024, 07:56 AM   #8
ooshnoo
ooshnoo's Avatar
Drives: 2014 428i and 2018 X5
2018 BMW X5  [0.00]
2014 BMW 428i  [10.00]
Watch this video. it tells you all you need to know
___________________
2014 F32 428i M-Sport
2018 F15 M-Sport
      03-28-2024, 02:02 PM   #9
Sato
Drives: M135i
thanks guys!
f30post
