11-20-2017, 02:30 PM | #1 |
Rep 337
2012 X5 50i Comfort Access problem
I recently picked up a 2012 X5 50i
The comfort access feature does not work. (and yes it has the feature according to bmwvin.com) The keyfob unlocking/locking and liftgate work fine using the buttons but having the key in your pocket doesnt work at all nor does it start the vehicle. no door handles work and doesnt even matter if its in your hand. Ive replaced the battery but no help. If you put the key in the ignition it will start just fine. Dealer wants $350 for a new key and reprogramming but no refund if that doesnt fix the issue. Ive tried all tricks to "resync/reprogram" the key to the vehicle that ive read about but no fixes. Dealer said they cant reprogram the existing key to the vehicle for some reason? Just wanted to check here to see if anyone else had any other ideas before going and purchasing the new key. Thanks |
11-21-2017, 11:14 AM | #2 |
Rep 1,716
Your Comfort Access System (CAS) could just be faulty. Mine has been faulty twice, wish it wasn't optioned with it. If just one door handle isn't working, I believe the entire CAS doesn't work. Mine got so bad that some other internal electronics started to not work. The radio wouldn't work - got the 'No Warning Tones' error. Brought it to the dealer and the door handle overheated during their test and melted it (shorted).
2016 F31 328iX | Alpine White | Black | ///MSport | iND | Eventuri | AC Schnitzer | MPerformance | 513M | Michelin PS4 |
2005 | 330CiC | Sparkling Graphite | Black | 6MT | ZHP Purchase your W///AGON Stickers Here: https://f30.bimmerpost.com/forums/sh....php?t=1930190 |
11-21-2017, 11:23 AM | #3 |
Rep 1,702
Handles work independently of each other. JDNY516 likely had a burned fuse, as I've experienced the symptoms he's describing when I pulled the fuse to do some testing.
Regardless, if no aspect of it is working, it's either your CAS Module or the fuse, but I'm leaning toward the former as the fuse also controls other things (i.e., gong). BUT, the fuse (#132 in the trunk) would be my first step at diagnosing this. Here's my journey through the issue and conclusion, hope it helps. http://www.xbimmers.com/forums/showthread.php?t=1372349 Good luck! |
JDAURIA725.00 |
11-21-2017, 12:38 PM | #4 |
Rep 4,057
I just had one CAS door handle replaced under warranty on Friday past. It all works fine now. Previously, the car would alternate every 5 or 6 days between none of the handles operating with comfort access - to all of them working except the faulty one. Throughout that, the car would always start with the fob in my pocket.
The fact that your car will only start with the fob plugged into the dash suggests to me that it may not be a comfort access issue; you may need the reprogramming suggested by the dealer, or the fuse, as noted above.
Huz-Z
BMW Z4 3.0si Roadster. Montego Blue Metallic. Premium and Sport Package. |
11-28-2017, 03:30 PM | #5 |
Rep 709
Do some searching here and on XOUTPOST.com, many threads.
I have seen a couple ppl mention diff issues, esp NOT having to pay the dealer to code the new key, they just drove home and it worked. Best to know all the possibilities before dropping trousers for them.
heatmizr [Todd]
g26 i4 e40 - Clean Machine e70 X5 50i M-Sport "The Boss" Loaded e90 328i - sold e36 M3 - Gone to become a track star |
11-28-2017, 07:57 PM | #6 |
Rep 2,736
Yea sometimes I question that stuff as my vin also said I have adaptive cruise control which I don't. So who knows!
The dealer can run your vin and give you a build sheet with all your available options. . It's a tad more reliable than 3rd party stuff. |
11-29-2017, 12:30 PM | #7 | |
Rep 7,489
The S544a option code above is standard/regular cruise control. What it does is...apply the brakes if the vehicle's actual speed EXCEEDS the pre-set speed. For example, if the vehicle is going down hill and the CC is set at 70 MPH...and the vehicle begins to creep up to 75 MPH...the brakes will be applied to keep the vehicle at 70 MPH. Again, the option code above is NOT Adaptive Cruise Control. Last edited by Qsilver7; 11-29-2017 at 12:40 PM.. |
12-03-2017, 08:02 PM | #9 | ||
Rep 2,736
But I swear it said adaptive. Never had issues with the other bmw's I've had but this was the first where I was like hey that doesn't make sense. Thanks though I can see why it be one to confuse. |
