      05-04-2015, 05:21 PM   #1
DiegoM
Drives: Alpine White
style 214 wheels/tire on E70 Diesel inquiry
Recently got a used 2010 diesel x5 as a track car hauler.
Would the 20" style 214 wheels with stock conti tires fit perfectly on this truck with no rub issues? Thanks so much
      05-05-2015, 12:41 PM   #2
serge1
Drives: X5 35d
2011 BMW X5 35d  [0.00]
Why wouldn't they fit? All X5s are pretty much the same..
      05-06-2015, 09:09 AM   #3
Draper
Draper's Avatar
3460
Drives: M4 Comp / Macan Turbo
They'll fit fine.
You'll probably will want to add rear fender flares if your X5 didn't come with oem 20s.
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic
      05-07-2015, 12:47 AM   #4
DiegoM
Originally Posted by jzbm3 View Post
They'll fit fine.
Thanks! Just making sure, because I noticed the 18" tires are almost touching the front upper control arm joint. Hence, concerned of rubbing with the 20"
      05-07-2015, 07:58 AM   #5
neliconcept
Fashion Photographer
66
Drives: 2013 Porsche Cayenne GTS
The 20" tires will kick out more so they will still fit. I have 19s and noticed the clearance being close but it's all about the offset. Check ECS tuning for the fender flare kit, because the wheels and tires will stick out a little past the flat flares we have. I'm going to be doing the same once I get these style 336 wheels.
      05-08-2015, 12:34 AM   #6
DiegoM
Copy that. Thanks.
