04-23-2015, 11:36 AM | #1 |
Rep 273
Ultimate-Racing.com downpipes
Just placed an order last night for their high flow cat downpipes and have already received confirmation this morning its been shipped. Thoroughly impressed!
Anyone have experience with their product (quality, fitment)? Planning on having them ceramic coated to try and keep temps down. |
04-23-2015, 12:05 PM | #2 | |
Rep 2,822
Drives: X5M F85
04-23-2015, 05:17 PM | #3 | |
Rep 273
Judging by the stock cats overall size I would guess flow rate to be that much better. Will be upgrading my stg 1 hex tune to stg 2. Another reason im doing this is from the heat generated. Hoping the ceramic coating, higher flowing cats, and exhaust wrap will greatly help. |
05-02-2015, 11:01 AM | #4 |
Rep 273
Had the high flow cats ceramic coated and installed this week. First impressions... quality of the downpipes are excellent (truth be told didn't have very high expectations given the price), turbo spool is instantaneous, power is effortless, and engine temps feels much cooler than before
05-02-2015, 03:08 PM | #7 |
Rep 273
True, didn't even occur to me. I wound up not even wrapping the downpipes because the stock heatshields we were able to modify and put back on. Between the headshield, higher flowing cats, and ceramic coating i didn't think it was necessary to go any further. The engine temps are significantly cooler than it was before.
05-02-2015, 03:43 PM | #8 |
Rep 1,292
Any recommendation for where to get and what brand of turbo blanket? I have a set of Ceramic coated AR Downpipes w/race cats on the way.
_____________________________________ 2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4 |
05-02-2015, 04:31 PM | #9 | |
Rep 273
05-02-2015, 05:22 PM | #10 |
Rep 1,292
Expensive for some rockwool insulation!
05-02-2015, 09:35 PM | #13 |
Rep 273
06-12-2015, 04:53 PM | #14 |
Rep 273
Follow up update.
Even with the high flow cats the car triggered a post o2 sensor fault code (p0156). Took a little over a month of driving to trigger but they came on nonetheless. Doesn't really matter however since I'm upgrading my tune here soon.
'08 IB / Extended Fox Red 6spd E92
'94 Red/black TT 6spd Supra '09 328i xDrive E90 |
06-12-2015, 06:09 PM | #15 |
Tanzanite Blue II X5M Pilot
1038
Rep 2,018
Drives: M3, M4, X3 M40i, X5M
Hmmmm - Should Gixxer pull the trigger on this?
06-12-2015, 09:19 PM | #16 |
Rep 273
I dont regret it at all. The tune made the biggest difference but the dp's did add some and the noise you get from the turbo's are worth the price of admission, lol.
06-17-2015, 02:27 PM | #17 |
Rep 170
Are the OEM heat shields mandatory or highly recommended? Active Autowerke's downpipe write-up says not to re-install them. I didn't install my heat shields back on and haven't noticed any adverse effects yet. Should I be worried? Should I install them back on?
06-17-2015, 02:42 PM | #18 | |
Rep 994
If you don't have a coating, you should put the factory heat shields on or use a wrap and turbo blanket. period. There isn't an exception to this. heat is bad.
06-17-2015, 06:10 PM | #19 |
Rep 472
I wouldn't go without heatshield especially when BMW places so many different plastic bits around the area. There won't be adverse effects to the exhaust or the hotside of the turbo, if issues arise, it would be to the other parts in the engine bay that is caused by over exposure to heat.
06-19-2015, 11:00 AM | #20 |
1038
Rep 2,018
I already have the Active Autowerkz tune and I am very impressed with it. Downpipes are the next performance step for me, however they (AA) want to sell me their downpipes for $1699 (ouch!) including a software upgrade for the tune that I already have.... I have been tempted to go with a more economical solution and have even considered buying a set of de-catted OEM downpipes, however, I have also been led to believe that the tune should match the downpipes (AA tune + AA downpipes) for optimal performance....
What do you guys think? |
06-19-2015, 11:35 AM | #21 | |
Rep 273
I purchased the dp's after I had already upgraded to the vf-engineering hex tune stage 1. After the downpipes, VF is only going to charge me the difference between the stage 1 and stage 2 tune.
06-19-2015, 11:59 AM | #22 | |
1038
Rep 2,018
