04-22-2015, 06:20 PM | #1 |
Rep 14
v10tt swap in x5m e70
can anyone tell me how to swap a v10 twin turbo in a x5m e70.
what flax plate do you use on the zf8hp. and can i fit water to air intercoolers under the rad or somewhere the in the front |
04-22-2015, 07:48 PM | #3 |
Rep 14
g power has made 5 x6m's with s85 v10s in them supercharged 900awhp
they used the x6m transmission with the s85. the e9x m3 with the s85 v10 they mite of used the m5 v10 transmission. |
04-23-2015, 09:28 AM | #4 |
Rep 2,822
Drives: X5M F85
04-23-2015, 03:45 PM | #7 |
Rep 3,647
04-23-2015, 09:33 PM | #8 |
Rep 40
Clearly a joke post, but seems like a match made in hell. V10 needs to be rev'd to the moon to get its measly sub 400 tq. Drop that into the heavy brick that the E70 is? Yuck.
04-24-2015, 11:22 AM | #9 |
Rep 19
I think adding twin turbocharger s to the S85 could make massive amounts of low end torque. Stock this engine makes good torque at around 3k rpm but not off idle like the n63/s63 motors.
04-24-2015, 11:29 AM | #10 |
Rep 233
The s85 can not handle boost, to high compression ratio, and to weak components inside..
It will never deliver more power than the s63 when it should live longer than a few miles.. Last edited by X Driver; 04-24-2015 at 11:47 PM.. |
04-25-2015, 07:43 PM | #11 |
Rep 14
i think it be cool to have 1200awhp v10tt s85 in x5m
i like to have top end power the most cause when i give it gas i like to have it 5000rpms and the s85 will have the power band all in the top. |
04-25-2015, 09:53 PM | #12 |
Rep 472
I'm sure it's doable, now the question is how much money do you have?? 100k? 200k? I'm sure someone will build it if you can write a check for 200k
Most of people on this forum simply does not know how to do it and don't think it would make any sense, but we aren't guys like G-power or PP-performance, if you have a target of 1200awhp, go for it, ship you car to germany and tell them what you want, I'm sure they will give it a try for you |
04-25-2015, 10:13 PM | #13 | |
Rep 14
i know it can be done i just wanta know if theres a factory flexplate i can use or i will get kiggly motorsports to stamp one out if they do that for a bmw they make mitsubishi cars. ill sub out the plate |
04-26-2015, 12:12 AM | #14 | |
Rep 11,135
04-26-2015, 10:36 AM | #15 |
Rep 3,995
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic |
04-26-2015, 06:56 PM | #16 | |
Rep 139
I do admire your hopes and dreams. But a twin turbo s85
"An on ramp is a terrible thing to waste"
EuroCharged Tune--QTP 3" Cutouts--V1 Hardwire--K&N Carbon Delete OEM Muffler Mod--(Best Mod Ever) 15mm Front Spacer--20MM Rear Spacer Last edited by WallyM5; 04-27-2015 at 12:15 AM.. |
05-01-2015, 11:32 PM | #18 |
Rep 994
The flexplate is the least of your worries. It's either the one that came from your engine, or the one that came with your transmission. Eitherway, neither will work and will most likely require a machine shop to make it right. You'll probably have access to either plate, so you need to take measurements and then adjust accordingly while working with a competent machinist.
