01-27-2024, 12:46 AM | #1 |
Rep 871
Drives: OG M2
N55 EWG Wastegate Adjustment?
I know that ISTA can walk you through the process of adjusting the wastegate but I was wondering if anyone here who has done it can help answer a question before I fully put the car back together: What has to come out in order to get to the adjustment bolt? Or can I reach down there with the car fully assembled?
OG M2 with the OEM M mirror retrofit
01-27-2024, 01:09 AM | #2 |
Rep 176
What's off the car currently? You can reach it from the top if you have small hands, but you'll have very little visibility. Its a lot easier to remove the downpipe and access it from the bottom.
VRSF RACE IC, FTP CP, VRSF CATLESS DP, BORLA ATAK CATBACK, CTS TURBO INTAKE, MST V2 INLET, PURE STAGE 2, TURBOSMART BOV,FTP TURBO OUTLET, SPOOL FX180, BM3 ETHANOL ANALYZER, PRECISION RACEWORKS COILS, BM3 STAGE 2+ E30
01-27-2024, 03:50 PM | #3 | |
Rep 871
Drives: OG M2
- downpipe - passenger rear engine mount - coolant expansion tank - inlet pipe - boost pipe I think I'm gonna try to get it as accurate as possible (I'm replacing my wastegate actuator itself) and see where it gets me
01-27-2024, 06:48 PM | #4 |
Rep 176
You should have plenty of room as it is now. It's going to be tough to get it exactly at 0.00. Ista and all of the scan tools i've used stop giving a measurement once you're within 0.5 and just says that no adjustment is needed. Get it to about 0.56 mm and go an additional 3/4 turn. That should put you very close to 0.00
samsamdar599.00 |
02-01-2024, 10:39 PM | #5 | |
Rep 871
Drives: OG M2
02-01-2024, 11:36 PM | #6 | |
Rep 176
Each Full turn is .75 MM. If its (-) you want to move it towards the front of the car. If its (+) towards the back. you want to loosen the nut closest to the front of the car first, then tighten the other nut almost 2 full turns(1.42/.75 = 1.89 turns) and then tighten the first nut to lock it in place.
samsamdar599.00 |
02-02-2024, 04:25 AM | #7 | |
Rep 871
Drives: OG M2
