      03-30-2010, 12:35 PM   #1
Georgepascal
Drives: BMW X6 3.5d
what would happen if...
your travelling with 100km/h and you shift (by mistake) to N (nutral gear)? It happened to me yesterday... i pushed the gear lever when trying to reach the cigar lighter and realised that i was running with >100km/h with N-Gear!!! I managed to stop the car safely, select D and run off again... Anybody knows what would happen if i shifted back to D while driving???
      03-30-2010, 01:09 PM   #2
ronald_adi
ronald_adi's Avatar
Netherlands
39
Drives: X6 40d
i have done it before. nothing would happen. It would just continue driving in D.
      03-30-2010, 01:15 PM   #3
chuck92103
chuck92103's Avatar
91
Drives: 2011 535i
+1 I put the car in neutral going downhill, my MPG goes up to 99.9 MPG.
2011 535i
2008 VW GTI
      03-30-2010, 01:38 PM   #4
watoowatoo
Drives: 09 35i X6
Actually if you leave it in D it will consume 0 gas as long as you don't accelerate but in N to keep engine running it consumes gas. Next time try in D you may get 99.9999 MPG
If people asked questions like you do maybe no one would have died because of Toyota braking problem. They could just put the car in N and stop the car! Basic driving knowledge!
      03-30-2010, 06:38 PM   #5
dmlgc
dmlgc's Avatar
Drives: 2022 BMW X6MC - 335D
huh ?
so with car in drive it consumes no gas but in neutral it consumes gas ?
Everyone keeps doing the "basic car 101 " routine, on the toyota hybrids it's all electronic. if the electronics fail you can't turn it off or put it in neutral, there are no physical links.
      03-30-2010, 09:22 PM   #6
x6xdrive50i
Drives: 2010 X6 50I
I got a question, what if I put the hand brake on when at 100km/h?
      03-30-2010, 09:27 PM   #7
chuck92103
chuck92103's Avatar
91
Drives: 2011 535i
Brakes engage and try to slow you down.
I toyed with all variations of tranny and brakes after the Toyota fiasco.
If my accelerator gets stuck, you can bet a dollar to a donut my X6 is stopping safely.
Only piece missing is if you tap on the brake while pressing the gas, the power does not cut out. A simple software update would address that. Not sure why they would leave out something so simple. But the car does turn off/on, emerergncy brakes work, and shifting into neutral works as well when driving.
2011 535i
2008 VW GTI
      03-30-2010, 10:29 PM   #8
watoowatoo
Drives: 09 35i X6
Most of these sad incidents happened bc of sticky gas pedal, not electronics failure. No one should be scared to shift to N like OP was.
huh ?
This is how I drive fast enough and at the same time conserve fuel when slowing down or going down hill. BMW engine uses ZERO fuel when you are going down hill in D and not accelerating. Mass energy of the car is enough to run the engine and the car. But in N engine is not engaged to wheels hence needs fuel to run. Just reset the fuel AVG and try it.
      03-30-2010, 11:41 PM   #9
dmlgc
dmlgc's Avatar
So you put it in drive and turn off the engine ? or you're saying the engine is on but because the car is going downhill it doesn't consume fuel, anytime the engine is on it consumes fuel.
      03-31-2010, 12:35 AM   #10
watoowatoo
Drives: 09 35i X6
Engine is definitely on and yes because the car is going downhill it doesn't consume fuel.
Same goes when you are braking. So when you are approaching a red light brake slowly to reduce speed and spend less time idling.
Let me know of your experience if you tired this. (By the way I think we have )
      03-31-2010, 02:08 AM   #11
archwerks
Drives: x6 3.5i VR
Best way to Save Gas
Put tranny in P, leave ignition off & put car in garage!
It defeats the purpose of ownership if u have to resort to these silly techniques.
Try shutting the engine off at long traffic stoplites, like they do in europe.
