05-02-2013, 04:07 PM | #1 |
Rep 841
Need help ! (disassemble plastic parts)
Hi guys ! Can someone help me out please.
I want to take off this parts for painting. I have absolutely no idea how to take that parts off. If someone can help me out I will be so appreciated. So this is what I want to paint. This is just a little makeup I want to make. I also want to put dark tint vinyl for front headlights I was trying to the whole grille with out hole for the headlights but I can't find it My skills in photoshop are bad. But here we go what I want to make. Thank you in advance for your help, tips and any advice. Regards -Avetis. |
05-02-2013, 05:01 PM | #2 |
Rep 841
Ok guys. I understand how to take this plastic out. Very easy just slowly pull out, starting from right side continuing to the left side.
This is how it looks like: The "mounting plastic clips" is soft so try to do everything gently. Last edited by GoodGuyAvi; 05-02-2013 at 08:16 PM.. |
05-03-2013, 10:36 AM | #3 |
Rep 333
Great info, thanks!
Instead of blacking out the fog and plastic piece, I am thinking about just taking out the whole section, and just put a mesh grill on top. |
05-03-2013, 10:42 AM | #4 | |
Rep 841
BTW I already put everything back ;-) Looks good (will upload the picture later today) |
06-04-2013, 12:53 PM | #5 |
Rep 333
Just talked to the dealers.
They have 2 concerns for me taking out the fogs: 1. If doing so somehow affects the electrical circuits, they will not honor my warranty. 2. They said they have no way of disabling the fog light error codes. I asked what about those people who installed performance bumpers? He couldn't answer. So in short, I am stuck with the fog lights. AvetNY, do you have any pictures of after painting the silver fog light trim and tinting the lamp? I might need to go with the same set up |
06-04-2013, 02:35 PM | #6 | |
Rep 841
I also didn't took my fog light out. Just to avoid the error. But I found something very interesting ! What do you thing about this |
06-04-2013, 02:46 PM | #7 | |
Rep 333
There is a recent post around here about LED fogs. Looking forward to your pics! |
06-04-2013, 02:51 PM | #8 | |
Rep 841
PS: That Anti-Flicker Capacitors will remove our error I think Last edited by GoodGuyAvi; 06-04-2013 at 03:03 PM.. |
06-04-2013, 03:14 PM | #9 | |
Rep 333
To remove the code error, we need to "trick" the car to think that the fog lights are still there. So, we can use a big resistor to do the job. I have successfully done this in my previous car (changing to LED signal lights), but mind you, the resistor gets very very hot. The best option, imo, is to do some coding to disable the fog lights once and for all.. My dealer said they can't do such coding though......... |
06-04-2013, 04:35 PM | #11 |
Rep 841
found this 2 puctures on my phone. I will upload more... Btw I recommending to use plasticdip. I did 9 times coatings. The result is excellent quality with 100% of matching color. (PS and big plus that you can always remove it) ;-) Last edited by GoodGuyAvi; 06-04-2013 at 04:49 PM.. |
