      08-31-2011, 10:10 AM   #1
motex
2020 Mineral White 30d MSport
motex's Avatar
Costa Rica
523
Drives: 2020 Mineral White 30d MSport
Exclamation Low Battery recurrent warning sign
Just wanted to know if anyone has had this issue before.
My car has visited the dealer a couple of times due to a warning sign of low battery, the car starts perfect but the warning keeps going on. They even change under warranty the turbo fans assuming the problem was there, but not.
If I stop the engine but leave the radio on, in less than 2 minutes, the car will pop up the warning sign and will cut all electric system, even the steering wheel retracts like when you close your car.
Here's a picture of the waring shown in my iDrive screen
Any help will be appreciated !
      08-31-2011, 07:41 PM   #2
LANDLORD
Turbo Engines are Fun
LANDLORD's Avatar
Drives: 2010 X6M Monte Carlo Blue
I think I would want a new battery.
      08-31-2011, 10:06 PM   #3
motex
motex's Avatar
Costa Rica
523
They say that was the first thing they checked, and the battery was OK......then I got a software upgrade twice and no change, I will push for a new battery....
      08-31-2011, 10:13 PM   #4
Mean_M3
Drives: 2009 E92 coupe
doesnt matter what they say, its either the battery or the sensors.....
      08-31-2011, 10:40 PM   #5
x5lover7777
Drives: 2010 x5m
it happened to me long time ago, dealer told me i had too many short trip. but they replace new battery
      09-01-2011, 09:49 PM   #6
motex
motex's Avatar
Costa Rica
523
Maybe I have the same issue, I drive 12 minutes to work, then 4 hours parked, another 12 minutes to have lunch 2 hours parked, another 12 minutes to work, and another 5 hours parked, and finally the last 12 minutes, thats my routine Mon-Fri , on weekends not much difference, and if it rains, I use my wifes Q7
Monday will be at the dealer for a test with a new battery, hope that will be the end of the story
      09-02-2011, 12:08 AM   #7
zaha
zaha's Avatar
Drives: Bmw X6M
Had the same issue.
BMW told me it's because of how little I drive the car. Some weeks I will drive 100km max. They said they would not replace the battery. I brought it in and they did a full charge and I bought a trickle charger which I used once or twice.
I do not believe it is the driving habit causing the error; especially in my car. I only had these messages pop up only in the winter. It gets pretty cold up here in Canada and from what I have heard from others, the battery does not fully charge when the temperature is -15C and below. Ever since the snow melted I have not seen this error and I have been driving just as little on a regular basis.
Hope you find a solution. Seeing that you are from Costa Rica, I doubt it is the freezing cold causing your problem.
      09-02-2011, 11:05 PM   #8
motex
motex's Avatar
Costa Rica
523
Originally Posted by zaha View Post
Had the same issue.
Thanks, be sure low temp is not an issue down here......
      09-05-2011, 03:12 AM   #9
Scouse
Scouse's Avatar
South Africa
Drives: 2009 X6 35d X-drive
I had the same problem about 3 months ago, BMW came and collected the car and took it for me to do some checks on it
At the end of the day they couldnt find a fault and so they replaced the battery for me, I havent had a days problem since, so i would definitely say its the battery, and im also in a warm climate as im in South Africa
2009 X6 35d X-drive, Vermilion Red
      09-10-2011, 05:16 PM   #10
motex
motex's Avatar
Costa Rica
523
Got a new battery under warranty, so far, no warnings......
      04-30-2013, 10:12 AM   #11
Spaceballs
Spaceballs's Avatar
Drives: 2010 Space Grey X5M
I had the same issue, and it turned out to be the IBS (?) battery cable. No issues since.
'10 Space Gray, Cinn Int.
      04-30-2013, 12:18 PM   #12
MaX6
Drives: 2011 BMW X6 50i
Originally Posted by jimmydetectors09 View Post
Among all the detecting activities, gold detecting is the most interesting one. It can not only relax both our mind and body, but also give us a big fortune if we are lucky enough. Next time when you feel bored, you can pick up a metal detector for gold and have a try.
I had a gold dector a few years ago.. Although it did work very well I decided to divorce her anyway...
      05-27-2013, 11:09 PM   #13
pha_roah
Drives: 2009 X6 35i
I had the same issue, took it to the dealer, they said I wasn't driving the car enough and as a result, the batter doesn't charge more than 30%, and refused to change the battery even though the car is under warranty.
Advice to anyone who gets this issue and doesn't drive the car every day: Before taking the car to the dealer to complain, make sure you drive the car a lot for about 30 days because they will print a log of the length of the trips you did in the prior 30 days, and if they think it's not a lot, will tell you that it's not covered under warranty because of your "driving profile"... go figure.
