      11-10-2015, 09:32 AM   #1
SlowBucksE70
SlowBucksE70's Avatar
Drives: Bmw X5 50i M Sport
BMW X5 50i Muffler Delete
I have a 2012 BMW X5 50i M-Sport package(4.4 Twin Power Turbo) and I would like everyone's honest opinion on a muffler delete
Unfortunately I can't afford an exhaust system for this car way to expensive.
All I would like to know is
How does it the muffler delete sound in the vehicle?
Does it bring any issues?
What kind of pipe should i use?
Does it void warranty?
What is it like at cruising speeds?
Just everyone's thought on this topic.
Is the Drone bad??????
SlowBucksE70
      11-10-2015, 02:06 PM   #2
Bigtimekegger
Bigtimekegger's Avatar
Drives: 2008 BMW 335i Coupe
sounds like shit. ive done it. changed it back within an hour.
      11-10-2015, 04:50 PM   #3
Cattivo
FDNY Engine 55
Cattivo's Avatar
Sounds great
      11-11-2015, 08:29 AM   #4
Bigtimekegger
make a 4 inch cut before the mufflers.. if you like the sound then take mufflers right off and pipe it to the rear bumper... should it sound like garbage... then simply re weld the 4 inch gap back in... I would imagine a reputable shop would do this for 100 bucks or so should you wish to change it back... and probably 350-4 to pipe the exhaust back to the bumper should you like the sound.
      11-11-2015, 04:58 PM   #5
TheVazha
Drives: X5Mmmkay.
Yeah I agree, super easy and cheap to test.
There is a set up I'm working on that will be the $500 Eisenmann clone. I will keep you posted! ?
      11-11-2015, 05:15 PM   #6
mitch808
Drives: 2012 X5 35i
Have you seen the Megan muffler back system? That thing is like what $400 or so? Much more affordable than some of the other "brand name," systems out there. Very good reviews from folks that have it.
      11-11-2015, 05:16 PM   #7
OldPueblo
Drives: f80 M3 Monte Carlo Blue & X5M
The forum and I would really like to hear your mod and get your specs! It looks like a muffler delete + replacement with a resonator?
      11-11-2015, 07:12 PM   #8
F06msportmia
F06msportmia's Avatar
Same thing happen to me. Did the muffler delete and brand new 4in tips in the morning and that afternoon I was back at the muffler shop and had everything back to original.
Don't do it! You will regret it.
I did remove the hose on the pump on the right side of the muffler and it sounds nice. Just wish I can have that on both sides.
      11-11-2015, 08:42 PM   #9
TheVazha
Drives: X5Mmmkay.
Starting off, I have to pay all respect to all the big names out there making A++++ product. Their designs are pieces of art if you ask me and worth every penny. The lucky few that get to own them I am envious in only the best way.
With that said, these parts are all really just exhaust pipe bent a certain way to either create power or sound or both. Some manufacturers have been able to get power out of their systems but not anywhere near the numbers needed to justify a $3K+ price tag. Especially for a part that will NEVER see the light of day.
So, taking the pressure off in trying to squeeze 10HP out of an exhaust system leaves you with a task of creating good sound. There is a combination of resonators and exhaust mufflers that will give you the sound you want. I'm working on that with a fabricator and as soon as I have something, I will share my set up for the price of free.
      11-12-2015, 01:49 PM   #10
badassfajita
Drives: 2013 e70 3.5i
Can you clarify this? Any error codes thrown as a result?
      11-12-2015, 02:57 PM   #11
Cattivo
FDNY Engine 55
Cattivo's Avatar
If you want your X5 to sound like an actual V8 I say do a muffler delete and use straight pipes...I get compliments every day on how angry it sounds from other enthusiasts
      11-12-2015, 04:12 PM   #12
F06msportmia
Of course... I'm sure I'm not using the right terminology.
On the right side there is a little pump that opens and closes some type of valve. Before the valve would only open up after the car is warmed up. What I did was remove the hose that opens and closes the valve and now the valve stays open. The sound is perfect and no drone. I just wish it was on both sides.
This is a pic of the muffler delete:
      11-12-2015, 04:14 PM   #13
F06msportmia
New 4 inch tips:
      11-12-2015, 07:50 PM   #14
SlowBucksE70
I would love to see the clone.. But what is this hose that I'm hearing about, I didn't even know the 50i had a valve...
Ooh btw people are charging me a little over $300 for a muffler delete
Which makes 0 sense too me..
And I can't find a proper axel back for this car that in my price range
SlowBucksE70
      11-12-2015, 10:03 PM   #15
mitch808
Drives: 2012 X5 35i
What is your price range?
      11-12-2015, 10:11 PM   #16
SlowBucksE70
Around $500
I seen one on the internet but unfortunately it's not for the 50i
Unless I get a y along with this
Idk
SlowBucksE70
      11-13-2015, 12:02 PM   #17
mitch808
Drives: 2012 X5 35i
Search for megan, in this forum, and you'll see what people did to install this on their car. It's a simple task for any competent muffler shop
      11-13-2015, 02:40 PM   #18
Cattivo
FDNY Engine 55
Cattivo's Avatar
The hose you're hearing about is the vacuum line that's attached to the actuator arm(pump/exhaust valve) that opens the valves at or above 3k rpm...the 50i doesn't have valves
      11-16-2015, 07:00 AM   #19
SlowBucksE70
Hmm getting the x5m Megan axel back and custom fitting it don't sound bad
SlowBucksE70
      11-16-2015, 08:04 AM   #20
socale39
Drives: 04 545i SMG
If any of you guys are in SoCal is highly recommend A1 Performance in Santa Ana. The owner, Tiger, has been featured on TV shows and does amazing work. The great thing is that he will work with you depending on what you are looking for. He is my go to guy and has done a few of my cars, all of which he did full mandrel bent Tig welded stainless steel systems....non of that crush bent you traditionally see.
      11-16-2015, 08:46 AM   #21
Bigtimekegger
I like his name.
      11-16-2015, 12:01 PM   #22
SlowBucksE70
I like his name.
Lmao
SlowBucksE70
