      10-16-2019, 05:54 PM   #1
mcastrodale
2008 X6
Drives: 2008 BMW X6
2008 X6 35i - Heat and A/C Problems!!!
I'm having heat and a/c problems with my '08 X6 35i as follows:
- The heat will only blow mildly warm if the temperature is turned all the way up to 84. If I turn it down a degree or two, it starts blowing cold air.
- The a/c blows ice code, regardless of the temperature setting. Once you get up to 82, it switches over to warm.
- The hot water control valve has been replaced.
Help!
      11-15-2019, 12:45 PM   #2
Too__Hu///Mble
Too__Hu///Mble's Avatar
99
Drives: 2013 X6 ///M
Offer a deal with the dealership to for an inspection in exchange you can get a discount on all item found.
To my knowledge get your whole coolant system checked first.
Then the ancillary items like A/C system, etc.
I have a '13 E71 M so I can relate. Change them out it's like new again.
