BMW 3-Series (E90 E92) Forum
KTMP-MOM is running at 65C is there something wrong
04-12-2024, 05:54 AM | #1 |
Rep 6
Topped up my coolant today as the light came on and I wasn’t sure how to check the temp on a bmw so I searched it up and the KTMP-MOM is the only temp gauge I could find online and when starting the car after topping up temps range from 30c on start to 65c when driving and 80c when stopped/idle. I found online diesel bmws are meant to run from 90-110c. Is KTMP-MOM the right temp gauge and if so what could possibly be wrong with my car or engine (if there’s anything wrong). BTW is drive a 2007 bmw 320d.
04-12-2024, 01:35 PM | #2 | |
Rep 4,066
https://www.carsaddiction.com/articl...er-hidden-menu If that Value is CORRECT, then it would appear your Thermostat is stuck open. One way to confirm that would be to watch for Radiator E-Fan operation with engine running at idle/ stationary. If ECTS is operating correctly, the E-Fan SHOULD increase speed or operate at 40 to 50% of max speed when temp shown on Instrument Cluster is at highest (80C?) If you/ a shop have/has INPA (or ISTA), you can use "F6 Activation" or "Triggering" Screens to view Fan, Coolant Pump & T-stat function, as well as ECTS Value. That works on E9x models with Electric Coolant Pump, Radiator/E-Fan, & T-Stat Heater. I'm NOT familiar with "Engine Cooling System" on 320d. THAT may Differ. Please let us know what you find. George |
JWeaves131.50 |
