      06-27-2012, 07:07 PM   #1
FlyAA757
Drives: '11 335i M Sport, '12 X5 3.5D
How long will the tires last?
I see there's are tons of tires threads...just got my X5d with 20" Dunlops.
Cn someone give me a ballpark of how far the tires will go?
Thanks!
2012 SB X5 3.5D, 2011 AW 335i M Sport
Retired: 2008 SG 328i, 2003 SG Z4 2.5i, 2010 AW 528i
      06-27-2012, 07:18 PM   #2
watrob
watrob's Avatar
Australia
140
Drives: MY2022 X5 M-Sport 45e White
Thanks!
I got 68,000klm out of my 20" dunlops and I am a heavy driver, I keep the tyre pressure up at 38lbs rear and 39lbs fronts, had perfect tread wear,.
Remember you need to keep the tyre pressure up on the rears as they tend to wear out the inner edge.
MY22 X5 M-Sport 45e White, 22"rims, Red Calipers, Ceramic Pads. Better off saying what it does not have and that's a B&O Audio System, otherwise all option boxes are ticked.
      06-27-2012, 07:39 PM   #3
FlyAA757
That would be fantastic..that translates to about 42, 500 miles. Seems to good to be true!
On my 335, I have 17,600 miles fit now, and my rears are nearing end of life!
      06-28-2012, 11:23 PM   #4
NRG
NRG's Avatar
Russian Federation
36
Drives: 2012 X5 35d
I'm at 20k km (12.5k ml) on my 20' Dunlops the rears are still 50% good, the fronts are almost done, about 20% left. I'd say in a perfect scenario you'll get about 25k miles out of them. In my previous 3 series both with 19' runflats B-stones I got not more then 25k ml with almost no burnouts.
Retired: 2005 N52 E90 330i Sport 6AT
Retired: 2007 N54 E92 335i Sport 6AT
Current: 2012 M57 E70 X5 xDrive35D
      06-29-2012, 03:13 AM   #5
GKyri
Drives: 2010 X5 30D
I got 28,000km from mine, probably would have lasted to 38,000km but I managed to get a hole that was just too big to repair. I used it as an excuse to change all four though as my Dunlops were terribly noisy to the point that I was hating the car. I went for Bridgestones instead and am far happier.
I honestly don't know how you did it Watrob - Brizzie roads are just as coarse as Melbourne. I will check my pressure though to see if they match your recomendation when I get a chance.
      06-29-2012, 08:18 AM   #6
watrob
watrob's Avatar
Australia
140
Were you running 20's? and did you keep the tyre pressures up?
      06-29-2012, 12:24 PM   #7
FlyAA757
Lol...in the same boat...almost no burnouts
      07-01-2012, 09:35 PM   #8
GKyri
Drives: 2010 X5 30D
Yes 20's but I won't lie I never checked the pressure.
      07-01-2012, 09:54 PM   #9
watrob
watrob's Avatar
Australia
140
My last set of runflats would drop from 40psi down to 35psi in about 30 days, the older the tyres got the quicker they lost pressure, also every time the x5 went to the dealership they would always drop my tyre pressures back down, it was a pain because I would have to remember to pump them back up.
