08-06-2016, 09:16 AM | #1 |
Rep 96
Lost auto up on windows
After a trip to the stealers to get my injectors replaced, I have lost the auto up function on my front windows. I have searched and no luck with the suggestions that I found.
Anyone have the reset step? Thanks Sergio |
08-06-2016, 09:28 AM | #2 |
FDNY Engine 55
681
Rep 2,115
Just hold the window switch up for 6 seconds after the window is closed
FDNY ENGINE 55...Liberalism: Find a Cure...http://www.xbimmers.com/forums/showthread.php?t=1127923
08-17-2016, 03:26 PM | #4 |
Rep 144
it may just be coincidence that your door seal sensor went bad. the seal has a safety circuit in it that may have a short and will cause the auto up not to work. had this happen to me not to long ago. both windows went though? sounds like a program or fuse issue.
08-17-2016, 03:28 PM | #5 |
Rep 47
On an LR322
Which had BMW tech you need to press up and have the window go all the way up, then press down till it goes all the way down. This then tells the regulator the upper and lower limits of the glass. Might be worth a try.
