03-22-2016, 11:30 PM | #1 |
6MT Fanatic
66
Rep 175
Base Stereo Upgrade - BavSound /w Hifi Coding review
I'll preface this: I've got a set of Focal IFBMW-S, IFBMW-Subs and Focal IC-100s in the rear of my 135i. I've had it EQ'd with a mike, and it sounds as close as I can get it to my Adam A7Xes /w Benchmark DAC2 HGC.
I wanted slightly better sound in my 2011 X5 XDrive35i but didn't want to spend too much/go through the trouble of adding an amp, since I thought I made a terrible decision and got an X5 with base audio. The EQ was sufficient to make the stock speakers sound slightly better than terrible. Making midranges play the highs was kludgey, but sufficient for a base stereo, I guess. I decided to give BavSound's X5 replacements a try, but only in the front. I didn't think it'd be worth using their speakers in the rear, since they only gave you the midrange. So it was either go with coaxials and pull the sound stage back some, or just use some other mids - I replaced the stock mids with silver BMW Hifi Top midranges I snagged for $50 off eBay. The speaker magnet is significantly larger and they're much better built. Post-install, I was less than thrilled. The EQ that made the stock speakers sound somewhat less than bad, made the high end shrill. The low-end was incredibly boomy. Tolerable when dialing both the treble and bass back, but anything above about 9k was still really bad. On a lark, hoping the iDrive had enough power, I recoded the iDrive from base stereo to Hifi. I heard everywhere that I might have issues with PDC/gong volumes or the sound not playing loud enough. Everything I read was incorrect. While with the stock coding, I could hear the tweeters distinctly from the midranges, the flat EQ coding to Hifi provides made the fronts seamless. The bass is now tamed, and I actually upped it a couple ticks in the tone settings. I moved treble down two ticks and surprisingly, aside from the stock subs still being a tinge muddy (Comparing this to the setup in the 135...not entirely fair), I'm extremely pleased with the results from just doing the BavSounds combined with the Top Hifis. The BavSounds are efficient enough to be driven off of the iDrive. Even to what I consider fairly high volumes. The disappointing thing is that BavSound doesn't mention that the way to get optimal sound out of their own speakers is to get the iDrive unit coded to Hifi. I even emailed them expressing displeasure in the quality of the sound from their speakers and asked if getting the iDrive coded to Hifi would help. I didn't get a response. Cliff's Notes: BavSound fronts + BMW Top Hifi rears + Hifi Coding = Legitimately decent sound upgrade from a base Stereo without adding an amp. Very pleased and happy. Just thought I'd share.
2020 M2 Competition | 6MT | Ohlins R&T 70/140 Swift Springs | CDV Delete | AudioTec Fischer MatchUP8 DSP /w Morel BMW Speakers/Subs | Thinkware U3000 Dash Cam F/R | More to Come!
03-22-2016, 11:58 PM | #2 | |
Rep 2,736
Cool non the less.... |
03-23-2016, 12:32 AM | #3 | |
6MT Fanatic
66
Rep 175
You could upgrade your hifi to top hifi, but that's beyond the scope of my post.
03-23-2016, 07:02 AM | #4 | ||
Rep 2,736
I think I have just the hifi but would like the top hifi or equivalent and just wondering how hard it would be to convert it. |
03-23-2016, 08:53 AM | #5 | |
Rep 10
did u add tweeter to the rear? or just midrange top hifi? |
03-23-2016, 02:06 PM | #6 |
Rep 3,651
I don't think you'd hear much difference between the Hi-Fi (option code 676) and Premium Sound (option code 677), they're nearly the same system. The base audio (option 645) sounds distinctly different…not sure what year X5 you have but 645's last year in the U.S. was 2011.
03-23-2016, 02:57 PM | #7 | |
Rep 2,736
They have a full retrofit with amp. Just looking for something that wouldn't require a full gut job. |
03-23-2016, 03:02 PM | #8 | |
6MT Fanatic
66
Rep 175
I just added the Top Hifi midrange to the rear. For $25/speaker, it was fine. I didn't want to spend too much money on rears, since I don't have a DSP to set up surround sound. But the BSW+Top Hifi midrange, with iDrive coded to Hifi sounds very good.
03-23-2016, 03:07 PM | #9 | |
Rep 3,651
I have 676 and I'm fine with it. I priced out an upgraded system (not Bavsound) and it was pretty expensive given all the speakers you'd have to replace and the amplification required. If I had 645 (which I've heard several times) I'd probably have done an upgrade of some kind. I believe that setup is only 6 speakers or so? Sorry about the thread-jack OP |
03-23-2016, 06:27 PM | #10 | |
6MT Fanatic
66
Rep 175
On the E70, when iDrive is coded to Hifi (entirely different head unit), the BavSounds /w Top Hifi rears sound significantly better. There's a whole lot of "it depends". I just wanted to post this to share that this is a combo that, to my fairly well-trained ears, sounds very good for the money.
03-24-2016, 07:35 AM | #11 | |
Rep 10
Tags |
bavsound, hifi, stereo |
