      10-21-2018, 05:25 PM   #1
BoostedNYC
BoostedNYC's Avatar
Drives: '21 X5MC - Marina Bay Blue
P112F Code
So this morning I turned my X5M on and noticed a cel light. I let it properly warm up and drive it around the block and it was driving fine, nothing out of the ordinary. I checked the codes cleared it and it hasn't come back. I've read a few threads pertaining to this code but there's not clear concise answer into "fixing" the issue. Anyone have dealt with this code?
01' e36 M3 ~ GONE
01 B5 S4 stage 3+ Tial 605s~OWN
      10-22-2018, 07:04 AM   #2
jandref321
jandref321's Avatar
345
Drives: 2012 X5M
Maybe this will help:
https://f87.bimmerpost.com/forums/sh....php?t=1399767
Could be the manifold pressure sensor also.
      10-22-2023, 06:13 PM   #3
Colodano
Drives: 2010 X5M
Long shot, but did you get this figured out? Hard to find anyone with this engine have this code come up. I have noticed what sounds like potentially a boost leak, but my short testing has not come up with anything obvious.
Only other code I am coming up with is a misfire that is fixed, but my scanner is on the fritz as well and wont clear, only read. New one is on the way currently.
I have had the 2D2E code on and off for ages, which I usually attribute to failing ccv hoses, as they are so brittle, but it seems like a related code as well, but isnt coming up currently.
      11-29-2023, 11:30 PM   #4
windsailor
windsailor's Avatar
Drives: 2013 X5M Black Saphire
Anything new, can't seem to find the leak location...
      11-30-2023, 03:17 AM   #5
525DA_touring
Drives: BMW E88 125i 2007; BMW E70 X5M
Check the ccv Lines, there is a vent inside.
This is damage and Puls this error Code.
13717848151 reinluftkanal
Left side can also Damage
