01-12-2017, 11:36 AM | #1 |
Rep 42
2009 X5 Rear Right Window Noise
Hey everyone,
I noticed an issue today where I get a horrible screeching (like metal on glass) noise at the top 1 inch of rolling up the rear right window. I don't see any visible damage on the glass or tint, so that is good news at least. I have read lots on the internet about regulators needing to be replaced in various BMW models, and read about either replacing the plastic clips that break, or using the "zip tie" method to fix the issue. However, this only seems to be relevant for the older generation X5's and other BMW models. Has anyone had this issue on their E70? Will similar cheap fixes work, or am I looking at having to replace the whole regulator? |
01-13-2017, 10:34 AM | #2 |
Rep 42
After work I had some time to inspect the issue closer. First thing I noticed was that the sound wasn't near as loud as it was initially yesterday morning. My first thoughts were that it was related to the cold weather, however upon closer inspection it appears that the weatherproofing strip along the window has fallen down into the window. I compared it to the other side and it looks like it is happening there too, but not to the same extent. Going to try and fix it this issue on the weekend.
Right side (where noise came from): Left side: Bonus pic of my X5 and my bosses X5M (I purchased my X5 from him): |
01-14-2017, 10:29 AM | #3 | |
Rep 45
I've replaced several BMW window regulators, it's not very difficult. I've always replaced the whole assembly, re-using the motor. There doesn't seem to be much difference in quality between the OEM units and other brands.
2013 E70 x35d
2004 E46 Sedan 2009 997.2 Cabriolet |
01-14-2017, 03:24 PM | #4 |
Rep 360
Nice looking X5's.
You might consider taking the door panel off. It's pretty easy and would allow you to inspect and fix it correctly. There are videos on YouTube on taking the door cards off. |
01-16-2017, 11:16 AM | #5 | |
Rep 42
Also got around to removing the phone cradle in the center console, and installed my radar detector/dash cam |
