02-22-2024, 08:33 PM | #1 |
Rep 18
Transmission Fluid ZF8 speed
I'm at 82K on my 435i and want to get my transmission and differential fluid changed. I don't want to do the work myself, so I called a indy shop I've used before. They quoted me $300 to change the transmission fluid without removing the pan. They said they use a transmission fluid exchanger, but everyone seems to be removing the pan when doing it diy. Whats your thoughts on this?
02-23-2024, 04:22 AM | #2 |
Rep 42
There is a filter in there that should be replaced as well. There is a kit that has a new belly pan the filter and new bolts. I would want that done as well. It is a bit of a process because you need to get the fluid to a specific temperature to perform the final top off.
LuxoM347.00 |
02-23-2024, 06:24 AM | #3 | |
Rep 3,203
02-23-2024, 07:49 AM | #4 |
Rep 18
Thanks, I’ll have them do the differential fluid for now and will ask about doing the transmission oil pan. Don’t want to do it myself, but might end up having to. Appreciate the feedback.
