      05-03-2015, 09:52 AM   #1
Salottox5m
Salottox5m's Avatar
Drives: F90 m5
slight ticking noise X5m
I have a 2011 x5m and i hear a slight ticking noise from car -- at BW a few months ago a tech said it should sound like that!
Just curious if everyone has or notices that?
Different question: battery died, charged and now these errors:
Can started this am after putting on charge for 2 hours...
now these errors are popping up
any ideas?
1. Chassis stabilization malfunction
2. DBC malfunction
3. Servotronic malfunction
(my buddy just said after i drive it, those errors should go away) we'll see
      05-03-2015, 10:35 AM   #2
Salottox5m
Salottox5m's Avatar
Drives: F90 m5
errors went off after i drove the car
ticking i still have of course
      05-03-2015, 12:19 PM   #3
gixxerboy63
Tanzanite Blue II X5M Pilot
gixxerboy63's Avatar
1024
Drives: M3, M4, X3 M40i, X5M
2017 m4  [0.00]
2010 BMW X5M  [10.00]
I think you hear the injectors ticking. Yes, that is normal.
2020 X5M - Tanzanite II
2012 M3 - Alpine White
      05-03-2015, 02:10 PM   #4
Salottox5m
Salottox5m's Avatar
Drives: F90 m5
ok thank you!
      05-04-2015, 08:19 AM   #5
WallyM5
WallyM5's Avatar
42
Drives: X5M, R63 AMG, F-450
I have the same thing too Bob.
"An on ramp is a terrible thing to waste"
EuroCharged Tune--QTP 3" Cutouts--V1 Hardwire--K&N Carbon Delete
OEM Muffler Mod--(Best Mod Ever) 15mm Front Spacer--20MM Rear Spacer
      05-04-2015, 08:43 AM   #6
hsc1102
Drives: 2010 X5M
I have a 2010 x5m experiencing the same sound, the SA says it's the sound from injectors and that is normal.
      05-04-2015, 01:42 PM   #7
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
injectors. This is normal unfortunately.
      05-04-2015, 06:36 PM   #8
eswimm
Drives: 2015 i8
Injectors tick, but the noise shouldn't be too loud in the cabin. If it is, then the bulkheads in the engine compartment may be separated. Very loud ticking may be lifters. I've had several replaced.
      05-05-2015, 09:41 AM   #9
Salottox5m
Salottox5m's Avatar
Drives: F90 m5
thanks.. not top loud.. buti notice it while outside my car at idle.. but BMW says its fine and your guys as well.. so just wanted to confirm bc i can't always believe the dealer
thank you all!
