      02-06-2018, 04:41 PM   #1
cbakking
Drives: E70-X5M
E70 - X5M oil residue under airduct hose issue
I took it to dealer when I spot oil residue under the airduct or CCV? (it looks like caked on over some period), they performed pressure test and told me nothing is leaking and seeing oil residue under airduct is normal for X5M? - is this true?
here's pic:
This is the part# 13717848151
http://www.realoem.com/bmw/enUS/show...diagId=13_1341
      02-06-2018, 04:48 PM   #2
Kraftwerk AG
Kraftwerk AG's Avatar
Drives: Mein F Fünfundachtzig Einhorn
Yep, I'm having the same experience. Only 33k on the odo too...
      02-07-2018, 08:11 AM   #3
philly42
Drives: X5M, Z3M
The CCV system is not the best in filtering out oil from crankcase gasses. Some install oil catch cans to reduce the amount of oil going through the intake system.
      02-07-2018, 08:46 AM   #4
jrmccain
jrmccain's Avatar
Drives: 2022 M5C
If you've ever wondered if a catch can system is effective....
      02-08-2018, 08:04 AM   #5
philly42
Drives: X5M, Z3M
Wow that's a good amount of oil!
Though not all catch cans are good in handling the volume. The small mishomoto that I had on the X5M wasn't filtering well. I swapped in the catch can from the supercharged Z3M in the X5M, since the filter and baffles are a different design. Fingers-cross that it does the job because I'm ready to move to the next project.
This is the oil I captured from the Z3M! The other pic shows a good area to check if your catch can is filtering well. There shouldn't be any oil there.
      02-08-2018, 06:24 PM   #6
Kraftwerk AG
Wow is right! Pardon my ignorance but where does all that oil go (if not trapped by the catch can)? Back through the intake manifold or returned to the crankcase? Thanks.
      02-09-2018, 12:29 PM   #7
philly42
Drives: X5M, Z3M
The valvecover is designed to filter out the oil and return it to the crankcase. If oil goes pass the valvecover it'll go to two areas....directly to the intake manifold and intake pre-turbo.
      02-09-2018, 12:33 PM   #8
Kraftwerk AG
Thanks!
      02-11-2018, 06:09 PM   #9
heatmizr
Drives: E70 X5 50i M-Sport
And that is all ok, as per design? It just gets burned up with intake charge?
heatmizr [Todd]
g26 i4 e40 - Clean Machine
e90 328i - sold
      02-12-2018, 08:53 AM   #10
philly42
Drives: X5M, Z3M
Yeah I think the design allows for a little bit of oil getting burned this way. Though over time the filtering components build up with oil film making it easier for oil to slip by. I even think the hoses coming from the valvecover was designed to capture oil as well. That "crinkle" hose design provides a lot of surface area and turbulence that help stop oil from going to the intake. However when oil fill in crevices, it allows vapor and oil to move faster through.
      02-12-2018, 06:50 PM   #11
protecon
*May contain nuts
protecon's Avatar
Australia
193
Drives: 2010 X5M MCB
The BMW system has a return to sump.
      02-12-2018, 08:11 PM   #12
jrmccain
jrmccain's Avatar
Drives: 2022 M5C
You must be talking about the newer S63TU engine. I have a '13 with the S63 that didn't have the new CCV system so the blow by went directly into the intake and turbos - wish I had the newer design!
This thread is pretty informative regarding the newer design:
http://www.xbimmers.com/forums/showthread.php?t=1245651
      02-13-2018, 08:22 AM   #13
philly42
Drives: X5M, Z3M
Right, I forgot that the diagram only applies to the TU. More reason to install a catch can.
