BMW 3-Series (E90 E92) Forum
Good Brands of Starters
06-11-2020, 12:12 PM | #1 |
Rep 16
My 2008 328i sedan needs a new starter, called my bmw dealership and they charge 470$ for a new one, what other brands of starters are good and reliable, ive read reviews on some but i want some more opinions, im looking to not spend that much money when i know there is other quality products for a cheaper price, is bosch a good brand?, thank you.
06-11-2020, 12:50 PM | #3 |
Rep 996
The Nightman1090.00 slattrick1.50 |
06-11-2020, 05:08 PM | #5 |
Rep 5,007
lowrydr3101689.00 |
06-11-2020, 05:52 PM | #6 |
Rep 148
See if you have a shop nearby that rebuilds starters and alternators. I just had an alternator rebuilt and the cost was 1/2 of anything new and probably better quality.
lowrydr3101689.00 |
06-11-2020, 06:09 PM | #7 |
Rep 2,243
Drives: 2007 328i / 2014 M235i
I went with Bosch which I hope lasts, maybe they improved the design because it didn't last very long.
The Bosch in my wife's Volvo is a much better design, the car has twice the mileage of my car and is still very strong |
06-12-2020, 10:45 AM | #8 |
Rep 1,579
I had one of the $130 rebuilt Bosch fail after 3 years. New bosch are $30 more. My latest starter purchase was a used on from ebay for $35. A one-year-old BMW OE part. Date codes can be seen on the sides of the starter in many auction pictures.
StradaRedlands4950.50 |
06-12-2020, 11:27 AM | #9 | ||
Rep 2,243
If it fails early I will use some Chinesium brand |
06-12-2020, 12:15 PM | #10 |
Rep 18,756
I bought two starters last September, one for my newly acquired E46 and one for the E90. The E46 failed a week or two after I bought the car, the E90 was in prep for a CCVectomy.
Both were re-man BMW OE Bosch units bought from getbmwparts.com. Been working fine. Seemed like quality units. Both were around $180 each. |
04-14-2024, 12:16 PM | #12 |
Rep 466
Drives: Break My Wallet
New BOSCH SR0492N is now made in China. Not sure whether that's a bad thing but hope it lasts.
04-14-2024, 06:08 PM | #13 |
Cometh
1090
Rep 1,308
Drives: Boy's Soul
Apparently the Hungarian made Bosch SR0492N starters are now SEG 0001.107.527
https://www.fcpeuro.com/products/bmw...-bosch-sr0492n https://www.fcpeuro.com/products/bmw...e-0001-107-527 "SEG Automotive is an OE producer of new alternators and starters. In 2018, SEG bought Robert Bosch OE Alternator and Starter production facilities worldwide. SEG has launched its aftermarket division to introduce its branded starters and alternators. SEG is an OE supplier to nearly every OEM for new Starters and Alternators, including the EV and Hybrid platforms." |
04-14-2024, 06:21 PM | #14 |
Rep 3,020
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
If you want to go with Chinese made, TYC has a good reputation:
https://www.amazon.com/TYC-1-17922-N...JZ0/ref=sr_1_1 |
Mike K322.00 |
04-14-2024, 08:11 PM | #15 |
Rep 1,173
I’d do Valeo. It’s what BMW switched to later as an OE supplier. Stay far away from Denso, IMHO.
FYI you should be able to use the uprated starter from an N55 with auto start/stop (F10 535i, for example). That starter worked very nicely on my N52. |
04-15-2024, 11:54 AM | #16 |
Rep 1,675
I had the infamous slow crank with the factory Bosch starter. Replaced it preventatively with a TYC off Rock Auto. Cranked strong and worked well for me for about $75 plus shipping. I would not put in a Bosch junk again.
https://www.e90post.com/forums/showp...4&postcount=94 I used a Harbor Freight version of this ratchet on the rear-facing starter bolt. You can also find e-torx sockets on Amazon. |
lordnikon370.00 StradaRedlands4950.50 |
04-15-2024, 12:13 PM | #17 | |
Rep 466
04-15-2024, 01:07 PM | #18 | |
Rep 161
I recommend a set of E-torx for working on these cars, regardless, but not for that bolt. I recently preventatively replaced mine @ 100k with the SEG that FCP lists as OE, since I had the intake manifold removed anyway. So far so good. |
04-15-2024, 01:40 PM | #19 |
Rep 582
This is one of the few parts where there is no such thing as a "Bad" brand
whyzee1251687.50 StradaRedlands4950.50 |
04-15-2024, 04:48 PM | #20 |
Rep 1,675
I have a CARB state N51, so it has the three stage intake with TWO DISA valves. I replaced both while doing the starter, along with the Bosch alternator voltage regulator and 3-way CCV brittle plastic pipe.
N52 two-stage system should have just one DISA?? I am not sure. |
04-15-2024, 04:51 PM | #21 |
Rep 1,675
An example Amazon E-Torx socket set, E4-E24:
04-15-2024, 07:57 PM | #22 |
Rep 3,020
All N52s have at least one DISA, while the 2006 330i models (the best!) have thwo DISAs. I don't know about N51s, I guess two? Do they have the extra hp as well?
