      08-16-2011, 04:50 PM   #1
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
Koni External Adjustable Rear Shocks Available now!
KONI Sport shock absorbers were developed for sporting drivers by focusing on exceptional road holding and handling properties, combined with an acceptable level of comfort.
The most economical way to get high-performance shocks on your BMW. These KONI single-adjustable shocks allow you to quickly adjust your rebound without removing from the car. The single adjustable struts are suitable for street and track days.
Short body for more compression travel.
Valved more aggressively than standard Koni Sport Yellows and can handle higher spring rates.
External adjustment located at the top of the shock shaft allowing adjustment without removing the rear shocks.
Fits 128i 135i 325i 328i 330i 335i
Includes: Koni bumpstops and mounting hardware.
$278 each
Buy here:
https://hpautosport.com/product/tc-k...-and-3-series/
      08-26-2011, 04:12 AM   #2
HP Autosport
Drives: F80 M3
We have 8 set of these on the shelf. Order away!
      08-26-2011, 07:47 AM   #3
larryn
Drives: '97 332ti, '21 X5 45e, '16 GT4
Though I like the option of having the externally adjustable shocks, and not having it exclusive to Dinan, I think that it takes about the same effort and time to remove the trunk liner to adjust (and reverse), as it does to jack the car up and undo the bottom nut to adjust (and reverse).
Of course, doing the trunk liner is cleaner than wrenching! Good to have options! Loving my Koni Sports still, Harold!
      08-26-2011, 07:57 AM   #4
MadMan77
↓↓↓ Ex-Con ↓↓↓
MadMan77's Avatar
Guam
34
Drives: Jet Black '08 135i
What might you pair there ones with? The standard Koni Yellow fronts?
      09-11-2011, 01:04 PM   #5
HP Autosport
Drives: F80 M3
Koni Single Adjust Damper - custom valved
These are not the your typical Sport Yellows with external adjustment added. These are custom valved and short body as well.
      09-11-2011, 06:35 PM   #6
MadMan77
↓↓↓ Ex-Con ↓↓↓
MadMan77's Avatar
Guam
34
Okay, so if they are specially valved rear shocks then I go back to my question: What front shocks are you to pair these with?
      09-28-2011, 11:09 PM   #7
HP Autosport
Drives: F80 M3
If you are not going with the coilovers, the Koni Yellows. If coilovers, then the threaded body front struts.
      10-08-2011, 03:40 PM   #8
HP Autosport
Drives: F80 M3
Koni Short Body Rear Dampers - More compression travel
Lowered car? Riding on rear bump stops? Need more compression travel or external rebound adjustable rear dampers? These are for you!
      10-03-2013, 01:36 PM   #9
HP Autosport
Drives: F80 M3
Bump!
      01-31-2014, 06:51 PM   #10
dcaron9999
dcaron9999's Avatar
Drives: 2011 135i M package
Originally Posted by HP Autosport View Post
Bump!
Hi Harold.
How well do these work with stock M sport springs, RE-11 tires, TRW M3 rear control arms? Do we need to remove the trunk liner each time we need to adjust the dampers?
I know we exchanged a couple of PM's on this, but still not clear to me ...
If I get the M3 rear control arms (BMW or TRW) either at the same time or later, which kit do i need to order now:
  1. "Koni Sport Strut and shock Kit E82/9X to M3 Conversion" kit
  2. "Koni Sport Strut and shocks E82 E90 E92 E93 1 and 3-Series" kit
I really want the rear external adjustability, but the first kit does not seem to offer this option...
Thanks.
2011 X3 35i with M pack + 2011 135i w/6SPMT | 255 square tire setup | Quaife 3.46 LSD | Diff lock down bracket | Bilstein B8+Swift SpecR springs+H&R FSB | CDV delete | BMS Oil Tstat bypass | ER FMIC & CP | N54Tuning DP | GC Street Camber Plates | M3 FCA +guide rods+RSFB's+Tranny mounts | Manzo toe arms | Cobb Stg2 agressive tune | Hawk DTC70 brake pads | RB SS brake pistons | Goodridge SS brake lines | Custom brake cooling ducts
      02-03-2014, 12:05 PM   #11
HP Autosport
Drives: F80 M3
Originally Posted by dcaron9999 View Post
Hi Harold.
Thanks.
This will be an upgrade if you currently have OEM or Koni Yellows.
Externally adjustable means the adjustment can be made externally from the damper. The Yellow standard adjust must be removed completely from the vehicle first. Dampers that don't require you to remove the trunk liner would be the external reservoir variety, which starts at $6500 and up.
The conversion kit for the M3 will always come with an external adjustable rear dampers.
      02-03-2014, 12:23 PM   #12
3002 tii
3002 tii's Avatar
2286
Drives: Z4 M, X5, GX460
Hi Harold.
Thanks.
You'll have to cut an access hole in your trunk trim over the shock towers so you can turn the adjuster knobs.
Follow for latest mods
      02-03-2014, 01:11 PM   #13
dcaron9999
dcaron9999's Avatar
My 135i is on OEM springs and dampers. Im thinking about keeping my stock springs for now, and adding an E92/M3 front sway bar to reduce body roll, and outside tire wear beyond what my camber plates are providing...
If I understand you correctly,
(a) the ""Koni Sport Strut and shock Kit E82/9X to M3 Conversion" combo you sell is compatible with stock dampers, stock springs, and whether or not whether my 135i uses stock rear control arms, or upgraded M3 control arms?
(b) the ""Koni Sport Strut and shock Kit E82/9X to M3 Conversion" combo comes with the external rear adjustment extension knob?
(c) I need to cut two access holes in my liner, right above the shock mounts.
      02-03-2014, 04:12 PM   #14
HP Autosport
Drives: F80 M3
(c) I need to cut two access wholes in my liner, right above the shock mounts.
The M3 conversion only applies to M3 rear camber link conversion. If you don't plan to upgrade the lower camber links, all you need is a regular kit.
http://www.hpashop.com/Koni-Sport-St...ut-e82-e9x.htm
Harold
      02-03-2014, 05:05 PM   #15
dcaron9999
dcaron9999's Avatar
Harold
Thanks Harold. Hate to be a pain, but can I recommend that you update your site to show the M3 conversion kit with possible options, exactly like you do for the regular kit?
(addition of External Adjustable Rear Shocks)
(addition of OEM E82/E9X Front Strut Mounts)
(addition of Swift Spec-R Springs)
Thanks.
      02-03-2014, 05:44 PM   #16
HP Autosport
Drives: F80 M3
Thanks.
Options added.
The M3 style rear dampers are already externally adjustable so there is no need for that option.
      05-06-2015, 12:03 PM   #17
HP Autosport
Drives: F80 M3
in stock
      06-10-2015, 11:38 AM   #18
HP Autosport
Drives: F80 M3
bump
      08-27-2015, 05:28 PM   #19
HP Autosport
Drives: F80 M3
bump
      09-17-2015, 11:18 AM   #20
HP Autosport
Drives: F80 M3
bump
      10-01-2015, 02:20 PM   #21
HP Autosport
Drives: F80 M3
bump
      10-13-2015, 09:45 PM   #22
HP Autosport
Drives: F80 M3
bump
1addicts
