Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > N54 Dyno Chart Compilation
      08-06-2010, 03:58 PM   #1
hun77777
hun77777's Avatar
Drives: SG E92
Arrow N54 Dyno Chart Compilation
trying to make this as "sticky" so that people can post their dyno chart with list of mods. i am fully aware of the fact that there are similar posts like this but most of them i've came across had ugly ends with pissing war between JB and Procede.
the purpose of this specific thread is not to see which is better, faster, quicker, higher hp. simply, just post your numbers just like N54 drag time compilation thread and have people to see what to expect.
just post your numbers and mention your mods(Stock, tune, upgraded turbo, meth, nitros, race gas), type of dyno (dynojet, mustang dyno, dynapack, dd etc etc), condition of the dyno day (humidity, elevation, time etc etc), dyno done at what psi and what gear pull and or whatever you feel that is necessary.
again, lets keep the discussion at minimum and please post your dyno chart along with it. my intention here is for general public to see many dyno charts possible, not to have pissing war between tuners, so, for tuners and their dear supporters, unless you are posting your own dyno chart, please keep the bashing, discussion minumum.
SGE92TT......................... 12.331 Sec @ 117.89 Mph............................POWERED BY
l BMS DCI l HELIX IC l FORGE DVs l RR OCC & CP & SCOOPS l AR 3" DPs l AE QUADs l BLISTEIN PSS10 l P3 VENT GUAGE l VISHNU PROCEDE V5 AUTOTUNE l Lots of Window Stickers
      08-06-2010, 04:19 PM   #2
Qmax03
LINEITUP
Qmax03's Avatar
Drives: 2010 335i MT AW
2010 335i E92 6MT. 4th Gear Pull
Very hot 95* Day...
Mods.
JB3 2.0 Map 7 / 93 Pump Gas
BMS DCI
AR 3" Downpipes
TS Exhaust.
      08-06-2010, 05:17 PM   #3
BrianMN
Drives: 4 Door Family Sedan
2008 E90 335i
Baseline of 265hp/280tq
PROcede v4 Autotuning
AMS Intercooler
AMS Catback Exhaust
VK Downpipes
CP-E Charge pipe/Tial BOV
DCI
100 octane
~19psi
Performed 5-6 good 3rd gear pulls before the dyno runs, but Autotuning was still learning on the third run
JB3 dynos are with same bolt ons on Map 7 on Pump Gas. (15-16psi)
      08-06-2010, 07:40 PM   #4
ultimateracing335
ultimateracing335's Avatar
Greece
35
Drives: blk 335i sedan with mods
Ultimate Racing exhuast
Ultimate Racing downpipes
Ultimate Racing intake
Ultimate Racing bov
Jb3 2.0
AEM methanol kit
Pump gas with 100 percent meth
      08-07-2010, 01:06 AM   #5
ericsmc83
ericsmc83's Avatar
Drives: 08 E92 335i MT
Mods and settings:
* 08 E92 335i 6MT (4th gear)
* MSD81 w/Original 29.2
* Vishnu V4 5/15 Autotune
* No Meth - UT 55 - IC 40 (15.5psi)
* Meth - UT 75 - IC 0 (17.5psi)
* Vishnu DCI
* AR Catless DP
* Helix FMIC
* Vishnu Meth Kit (70/30 mix)
* Stock CP/DV
* 3/8-Tank Trick 101 Octane
Conditions:
* 77.23 deg F
* 30.08 in Hg
* 24% humidity
2008 E92 MT | VTT Stage 2+ 20T | VTT Inlets | JB4 MHD E85 | Fuel-It Stage 3 LPFP w/FPR and Return | BMS PI | AR DP | AE Quad Exhaust | Helix FMIC | ER CP | Tial BOV | DCI | AR OCC | Spec Stage 3+ | SMFW
      08-07-2010, 11:07 AM   #6
BrianMN
Very hot 95* Day...
Mods.
BMS DCI
AR 3" Downpipes
TS Exhaust.
This graph seems very odd.
Every other N54's HP drops off after 5500rpm...yet this one climbs to a redline of ~7350?
      08-07-2010, 12:48 PM   #7
shyestsparks
Drives: 335i sedan, 02 Altima VQ35DE-T
V4 05-15-20 autotuning map running 17 lbs. of boost, 0% IC.
Fuel: Sunoco 110 oct. leaded
N2O jet: 0.32 (0.28 on run 29)
controller: Dynotune single stage controller to turn on @ 3500, off @ 6500
wheels and tires: heavy ass 19# Beyern Mesh and Nitto 555s
N2O bottle pressure: 900 on run 33, 700 on run 29
other: methanol injection 75/25 mix, twin nozzle setup with an M10 nozzle as primary and an M7 secondary nozzle to be triggered with the N2O.
Most bolt ons.
I wasn't able to change my spark plugs before the dyno runs (I had about 10,000 tuned miles on them). That's why we saw a misfire and had to stop at 6300 rpm.
      08-08-2010, 02:53 AM   #8
Jlomb436
Drives: 09 E90 Space Gray 335i
Bump to see a 335i dyno with just jb3
      08-11-2010, 01:26 PM   #9
J x K
NF@ E82
J x K's Avatar
Drives: E82
135i 6mt
JB3 2.0 18ohm, Custom Map 1
AR downpipes
Custom 3" Exhaust
BMS Intake
Active autowerke IC & piping
Stett charge pipe
Coolingmist meth kit
99% methanol with a splash of water
93 pump gas
77 degrees ambient, %? Humidity; it was raining
Baseline dyno was 295/297 bolt-ons w/ no tune
NF@ Jet Black E82 N54
451Whp/448Wtq @19psi; Pump gas & Meth
JB3 12 OHM
Tuned by: Terry Burger
http://www.youtube.com/user/E82jxk
JuniorB184.50
      08-11-2010, 04:33 PM   #10
Mike@N54Tuning.com
Joint Chiefs of Staff
Drives: 2007 335i, 2015 M3
JB3 2.0 with bolt ons, 91 octane, map 7 and JB3 2.0 with nitrous, meth, and race gas.
Also the third graph shows customer same car dyno comparison of JB3 and PROcede, all bolt ons with 93 octane, each with custom tuning
Mike
JuniorB184.50
      08-16-2010, 09:37 AM   #11
STONEY_M5
MAAD HEAD
STONEY_M5's Avatar
Drives: 2010 X5M 2013 M5
13 F10 M5  [0.00]
2010 X5M  [0.00]
07 335i  [9.26]
Mike
SHIT!!!!!!!
F10 M5 e70 X5M
Sold E90 335i
      08-16-2010, 10:28 AM   #12
arc1880
Drives: '07 335i (e92)
Same. Also a 335i with vishnu.
      08-19-2010, 12:04 AM   #13
BrianMN
Very hot 95* Day...
Mods.
BMS DCI
AR 3" Downpipes
TS Exhaust.
Mike- Can you provide any insight to this dyno/graph?
Every other N54 dyno I've seen drops off HP at 5500rpm, whereas this one keeps climbing til '6700' rpm.
Also, it appears this engine has a rev limiter of 7350rpm.. or something that makes the graph appear to fall off at 7350 instead of 7000.
Maybe DynoDynamics just read/show rpm and power funny? Can you explain at all?
      08-26-2010, 04:26 PM   #14
Tony30TT3
Drives: 07 crimson red e90 sport step
e90 auto 30k miles
003 run DCI only 93 pump (freaky strong stock, my friend with 335i e92 full bolt ons stock tune 6spd only put down 292whp right after me)
007 run dci jb3 1.4 map 7 100 octane
005 run dci jb3 1.4 map 8 100 octane
      08-31-2010, 05:11 PM   #15
M3 Eater
M3 Eater's Avatar
Drives: 335i Sedan
2007 335i  [0.00]
Jb3 2.0 7/4, Ar Down Pipes, AeM Dual Cones (dry), Hyperboost DV's, Labonte Progressive meth, DO 250psi pump, Cooling Mist M 5 and CM 5 Nozzles.
This isn't my fastest 1/4 but it is one of the highest WHP @ 435.
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
      09-05-2010, 01:25 PM   #16
hmonay
Drives: na
Originally Posted by BrianMN View Post
2008 E90 335i
AMS Intercooler
AMS Catback Exhaust
VK Downpipes
DCI
100 octane
Did you have the same mods on the JB3 and the PROcede
When you did those runs?
      09-05-2010, 02:22 PM   #17
Mike@N54Tuning.com
Here is a recent dyno of my car..
The car is modded as follows
335i [This is the Northern BMS testing car ]
Street Tires, 19" M6 Rims
JB3 2.0 - 18ohm board (7/4 Firmware) - OFF the Shelf maps (no custom tuning run today)
PUMP Gas - Sunoco 94
Coolingmist VC-2 Meth Kit (CM7+CM5 dual nozzle setup into an ar design Meth Elbow [90/10mix])
ar design catless downpipes with STOCK exhaust
Helix FMIC
Forge DVs
BMS DCI
      09-05-2010, 02:35 PM   #18
BrianMN
No Definitely Not. I will write some more clarity into the thread.
JB3 = Map 7 on Pump Gas (15-16ish psi)
PROcede = Race Gas (19psi)
      09-05-2010, 08:48 PM   #19
ktmsmr12
ktmsmr12's Avatar
Drives: 2019 X3 M40i
These runs were pretty much back to back and we only had one small fan in front of the car. We did a few runs and then we let the car cool for 20 minutes and did a few more. It was a dynojet dyno. As he was dynoing the car, there were several times where the car kicked down from 4th to 3rd gear and ruined the run. Not really sure if that affected my runs or not, because the good, full 4th gear runs always took the 3rd or 4th pull to do properly and I assume the car had heat soak by then.
Conditions:
88F with 70% humidity
900 ft ASL
2007 335i E90 Steptronic
FBO's
CM10 100% VP M1 Meth
93 octane
JB3 15-ohm on Map 10 - straight map with defaults
      09-09-2010, 01:54 PM   #20
q8-tii
q8-tii's Avatar
Belgium
11
Drives: 2009 335i DCT (sold)
2009 335i  [0.00]
Bone Stock 93 Octane was about 68 Degrees F outside, didnt feel any humidity outside. (It was an All Wheel DynoJet)
Full Mods, although JB3 was at version 1.4 map 7. (In My Signature below) 93 Octane, same temps as above, but different Dyno (Rear Wheel only DynoJet).
09 E92 335i - Jet Black - M-Tech Full Body Kit - DCT - OEM M-Tech Front CF Splitters -OEM Gloss Black Individual Shadowline Trim - 19" Style 230 Rims (Painted Matte Jet Anthracite)- CF Mirror Covers - OEM M3 Trunk Lip Wing. MODS - JB3 2.0 - BMS DCI - AR Design OC - Helix FMIC - Stett CP - Forge DV's - MS 3" Coated DP's - SuperSprint Catback
      10-21-2010, 12:25 PM   #21
m54b25
Drives: exM3, exX5, 335i, C63 RT
Modified PAW Motorsport 135i Flashed for 93octane w/upgrades:
http://www.e90post.com/forums/attach...1&d=1287680853
      10-25-2010, 10:16 AM   #22
Quisp
Does not play well with others
Dinan Stage 3 with intercooler and larger oil cooler. Also shows with stock software(dotted line).
(The people at Dinan weren't completely happy with these numbers and we are working on it. They feelit should be able to get 20% more HP)
