BMW 3-Series (E90 E92) Forum
How to remove N55 Cylinder head (n54 owners can chime in)
01-29-2017, 10:11 AM | #1 |
Rep 98
Hey there! Im actually a 135i owner but figure there's more 335's out there.... i have an N55 and was wondering if anyone can tell me if i need to remove the cams go access the head bolts... also, do i need to buy the cam alignment tool/holders to take the head off? Im already buying the fuel injector removal tool, just wondering how to get the head off once iv got the VC off... i know its a stupid question, but its not obvious to me
Im not looking for the people that will say "if you cant figure it out then let a professional do it" iv done many head gaskets and am aware of the oddities of doing it to an n55.. just need clarification before i take it apart.. thanks!
01-29-2017, 12:48 PM | #2 |
Rep 168
You need the flywheel locking pin, camshaft locking tool and vanos timing plate for this job.
2012 335is DCT - JB4 - MHD - Fuel-it! - DocRace
Bimmer 808170.00 |
01-29-2017, 01:03 PM | #3 |
Rep 98
So basically this? Do i have to remove the cams? I am expecting a damaged block or head, i really just need to see inside
01-29-2017, 08:55 PM | #5 |
Rep 229
Drives: 08 E90 335i 6 spd MT
dam. if u weren't aware of the timing lock kit necessary to remove the cylinder head. I'd say let someone with more experience do this.
01-29-2017, 09:02 PM | #6 |
Rep 98
Dont worry about me, i didn't know how to take an m20 head off when i started working on them. Now i could have one off in 30 minutes. Everything is hard the first time, thats why im asking about something i am unsure of.... iv completely taken apart an s52 head before with no ill effect, i am sure i'll be fine. Also, can you read?
01-29-2017, 10:21 PM | #7 | |
Rep 168
01-29-2017, 10:39 PM | #8 |
Rep 229
no. I also can't write.
01-30-2017, 05:33 PM | #11 |
Rep 229
thats exactly what i was thinking.. but i cant read so what do i know.
02-01-2017, 08:02 AM | #12 | |
Rep 98
Anyways, i ordered...
02-01-2017, 08:14 AM | #13 | |
Rep 573
SEARCH my diy for cam ledges on my older car you can rent the timing alighting kit for $40 i think it comes with the flywheel locking pin and you're going to need it to install it back in anyways. and yes all that has to come off to remove the head. Keep in mind there are no timing marks in the sprockets or anything else hence why you need the alightment tool. Put it in DTC mode lock the flywheel alight the tool take pics of the chain make your own markings just to be sure and starting tearing it apart. |
feuer4275.50 |
02-01-2017, 08:17 AM | #14 | ||
Rep 98
02-05-2017, 08:48 PM | #16 |
Rep 3,189
Bolts are easy to see with the VC off. You better get the right torque sequence and a good angle torque wrench. You do not need to remove the engine/trans. The little pin in the kit is to lock the trans/crank if I remember correctly. So why have it if you are separating them. Better be strong and have a engine hoist. It's a bitch to get off/on.
02-06-2017, 09:21 PM | #17 |
Rep 573
yes you can do it in the car, it's labor intensive and a lot of stuff hast to come out think about it your taking the cylinder head off you can't take short cuts.
02-06-2017, 09:24 PM | #18 | |
Rep 98
02-06-2017, 10:24 PM | #19 | |
Rep 573
If i had access to a lift which the manual assumes you do. Bringing the engine trans cradle down would be easier then to remove the head on the car. Once you have everything lowered it's easier to work on the timing, head swap, removing turbos alone is a pain in the ass (n54). |
02-06-2017, 11:30 PM | #20 |
Rep 98
Its funny though, they want the transmission removed before the engine... like you slide it off the back of the motor, then grab the engine by itself... the manual still has you using a cherry picker anyways... if i dont have to pull the engine/tranny if i dont have to i wont!
02-07-2017, 09:06 AM | #21 |
Rep 573
like weehee mention you do not have to separate the trans engine you lock it with the lock pin AFTER you set it to TDC.
it doesn't take long to lower the engine with a lift certainly worth it. to set the car to TDC you need to look at the back of the camshafts with a mirror so it can be done but it would take longer and more cursing. |
02-19-2017, 09:43 PM | #22 |
Rep 98
To the hater taters.... also like to add for anyone looking to do this, be prepared to use a 4mm Allen head to rotate the valvetronic worm gear to gain access to one of the T-60 Torx head bolts on the intake side, you'll also have to remove the 13mm stopper for the valvetronic eccentric shaft on the intake side. Its impossible to reach the timing chain area head bolt thats under the drivers side guide without removing the Allen head plug that reveals the upper guide locating sleeved bolt type thing that holds the guide in place (which is made even more apparent when trying to lift the head off, where you must squeeze the guides together) also, buy the special bmw or equivalent T-50 Torx bit (its really long and skinny with a 3/8" drive)
terryd5150507.00 houtan707.00 |
