      04-07-2018, 02:43 AM   #1
Dclok
Drives: 2008 X6
2008 X6 E71 Xenon light bulb removal help
Hi all, i tried searching the forum but couldn't find anything that assists me. I'm trying to replace the front xenon bulb without removing the headlight. The below makes it sound simple but I just can't clearly make out bulb holder nor will it rotate easily. Does anyone have any tips or advice? Thanks in advance for any help.
http://www.bavarianmw.com/guide-1279.html
      04-07-2018, 03:33 PM   #2
jinuwin
jinuwin's Avatar
Drives: F82 M4 GTS / E71 X6 35i
Check this YouTube DIY (/watch?v=bPeVE4mf-oA). Same process for X6.
      04-07-2018, 07:47 PM   #3
Dclok
Drives: 2008 X6
hi jinuwin, thanks for the reply. i saw that video and unfortunately the x6 doesn't appear to have the paperclips, not from i can see? I took a pic.
From what i have read there is a black plastic bulb holder which snaps around the bulb. i thought i have to rotate it out but id like confirmation of this as im not having any luck.
      04-10-2018, 03:50 PM   #4
Colodano
Drives: 2010 X5M
Yeah you have to rotate it. It will be a pain the first time, but gets easier. I like to unplug the wiring before turning it as well. Once the bulb is out, the little black clips pop off and go onto your new bulb.
