      07-15-2017, 04:03 PM   #1
Frankkao14
Drives: 2012 BMW X6 50i
Having trouble replacing the turn signal bulbs
Hey all,
I know the instructions are easy,
1. Locate the bulb
2. Twist counter lock wise to remove the bulb
But I have trouble twisting all the way to pull out the bulb.
Somehow it feels like it stops turning after a quarter turn and I can't twist anymore and the bulb won't come out....
Any info will be appreciated
      07-15-2017, 07:20 PM   #2
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / F15 X5 50i
Instead of continuing to try to twist the bulb cover/holder counter clockwise...when it stops at the 1/4 turn...pull (or pry) outward on the bulb instead of attempting to continue twisting. It may be slightly ceased due to dirt/dust/grime and need some gentle persuasion. If enough space develops pry with a flat head screwdriver to help push it outward.
If the bulb holder is like all of the bulb holders on my BMWs...there is usually 2 - 4 tabs that secure the bulb holder...and it only takes a 1/4 turn to lock/unlock the holder...then you pull the holder out.
If it looks like this...then there is another tab that prevents it from being able to turn 360°:
{cover/lid/holder}
{bulb}
