      10-19-2011, 09:15 PM   #1
263464757
Lt. General
263464757's Avatar
Drives: X5 5.0, 540i, 1965 C2
That Squeak!
After driving, Sav parked in garage, for about the next 2 hours, every so often you here a faint squeak that has a resonance to it...eeeeeek!
Is that the suspension that's bleeding off...Anyone know?
I always notice it at night when I'm working around the car. Just curious!
      10-19-2011, 11:22 PM   #2
WWONG
Drives: 2012 BMW X5 xDrive35d
Sounds like something to do with the battery turning itself on and off and every time power is received, the fuel pump primes.
You should hear what a 335i sounds like when it's off. Random thudding every once in a while.
      10-20-2011, 12:16 AM   #3
263464757
Lt. General
263464757's Avatar
Uh...Never here that ...why would the battery turn on and off if the car has been turned off?
      10-20-2011, 03:01 AM   #4
WWONG
Most likely to save power + keep the alarm system (notably the clown-nose LED on the mirror and accelerometer)/BMW assist transceiver/key transponder working.
      10-20-2011, 06:47 PM   #5
14bmws
Drives: 2008 M3 Sedan
When I unlock my 2012 35i, it sounds like air shocks filling up for about 5 seconds. I wonder every time. Also, the radio and wipers will not turn off unless I lock the car. Can't figure it out.
      10-20-2011, 06:48 PM   #6
JOcampo
Drives: 2009 X6 5.0
same thing here, wipers keep on going lol
      10-20-2011, 10:59 PM   #7
263464757
Lt. General
263464757's Avatar
Spent about Two hrs in the garage tonight...waxing/rotating tires. After paying close attention I'm almost positive it's the suspension letting down.
I did another test. Open the door, ignition on, left ignition on for about 8-10 min...ignition off, laid underneath rear end, after about 5-8 min, rear end dropped quickly and dramatically about a half inch.
Which brings up another question...rear end, center of axel and on top, forward of the shock there's a large shock/strut. Is that an airbag?, or do they just cover up the coil...if we even have coil's. Note: I have adaptive drive if it makes a difference.
I should have taken a pic...I had the wheel off.
