      10-02-2019, 12:46 PM   #1
passthetongs
Drives: E70 X5 Xdrive35i
High mileage 2011 E70 35i fluid change
Hey guys, my e70 has just hit 130k miles and I was concerned about a full fluid change. Ive read about not touching the ATF if its this high... I plan on keeping it for another few years, so should i do a drain and fill, but no flush? Everything shifts great, and no issues. Also, should i go ahead and get the F/R diff and transfer case fluids changed? I also have a slow leak in the oil pan (maybe 1/2 quart added every 5000k miles). Also do yall know a rough fair estimate for everything to be done? Just dont want to get ripped off. Thanks in advance!
      10-03-2019, 01:29 PM   #2
mitch808
Drives: 2012 X5 35i
I've heard the oil pan repair is expensive. The engine has to be supported from above and the lower subframe dropped or something... Basically well over $1000 in labor alone.
I have the same issue, but it's pretty small in terms of the leakage.
