Pandora Car Alarm System
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      06-15-2017, 10:40 AM   #1
krotondo
Drives: 2017 AW/Full SO M3 ZCP
LED Halo Brightness Coding Question
Creating another thread for future searching purposes
Anyways, none of the cheat codes for brighter halos are for LED's
I did some digging when coding off my amber side LED's
See pic below, is the 9th Werte value in related to the Halo brightness? I see it at 64 now, will changing it to 100 in Standicht Modus 1 & 2 for LHM 43 & 43 make my Halos for LED @ 100% all the time?
Figured I would ask before I code. Also not sure if any changes are needed in FEM_BODY, I would rather understand how to change this manually than use a cheat code.
Thanks in advance!
      06-15-2017, 11:28 PM   #2
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
  1. Any vehicle with Xenon's or LED's has secondary light modules (eg, LHM/TMS in '15-'17 F80 or FLE in '18 F80) and coding is only changed there.
    • In your case, the coding is found in TMS (as pictured) & leave FEM alone.
    • The easiest way to determine which werte value to modify is to compare Tagfahrlicht (DRL) to Standlicht Modus 1/2 (low beams/driving).
  2. Werte values are in hexadecimal. Do not change 64 to 100.
    • Angel Eyes go from 100% (64) to 46% (2E) with low beams.
krotondo118.00
      06-16-2017, 08:26 AM   #3
krotondo
Always have the answers! Big thanks
      09-07-2017, 01:35 AM   #4
hyperspeed
hyperspeed's Avatar
Drives: 2018 R8, MYP, GLE
A couple questions:
1. For LED headlights, were you able to disable amber sidemarkers?
2. For LED headlights, were you able to increase the Angel Brightness to 100% with low beams on?
2018 F80 M3 AW / SO
      09-07-2017, 02:25 AM   #5
Almaretto
Almaretto's Avatar
2374
Originally Posted by hyperspeed View Post
A couple questions:
In every car I have coded, this is possible. Though, 100% gives a washed out look that is also glaring to other drivers and I would advise against; instead, try 60%.
      09-07-2017, 12:22 PM   #6
hyperspeed
hyperspeed's Avatar
Thanks. I'm trying to understand how hex digits work / read... i'm guessing 60% = 3C?
2018 F80 M3 AW / SO
      09-07-2017, 12:38 PM   #7
Almaretto
Almaretto's Avatar
2374
Correct. Though, confusing part for FLE's is that Group 3004 number references 3005 behavior. As such, you do not directly set to 3C in 3004.
      09-07-2017, 03:32 PM   #8
hyperspeed
hyperspeed's Avatar
For my purposes, just coding 3005 is what I need to do, correct?
Compare Tagfahrlicht (DRL) to Standlicht Modus 1/2 (low beams/driving) to find the correct value to edit?
2018 F80 M3 AW / SO
      09-07-2017, 03:36 PM   #9
Almaretto
Almaretto's Avatar
2374
Incorrect. That is what you do for TMS. For '18 with FLE, it is DRL_Idx to POL1/2/3_Idx. And, as stated, you cannot directly change just werte value there to desired intensity as those 3004 wertes are references for 3005 values.
      09-07-2017, 03:37 PM   #10
hyperspeed
hyperspeed's Avatar
Another question sorry...in another thread regarding disabling amber sidemarkers with LED headlights, I got these instructions to code the TMS as per below.
For an '18, will I be doing exactly the same, but with the FLE instead?
-- Instructions --
For LED headlamps:
You'll need to FDL code both TMS modules (one is for the left light, one is for the right)
Within TMS, search for Standlicht Modus 1 & Standlicht Modus 2, and change the Werte Value 64 to 00 as follows:
Original: 00, 03, 00, 00, 64, 03, 00, 00, 64, 03, 00, 00, 2B, 04, 00, 00
Change: 00, 03, 00, 00, 00, 03, 00, 00, 64, 03, 00, 00, 2B, 04, 00, 00
2018 F80 M3 AW / SO
      09-07-2017, 03:46 PM   #11
Almaretto
Almaretto's Avatar
2374
General theory for determine which werte to modify is correct. However, you will not find Tagfahrlicht & Standlicht Modus 1/2 in FLE.
Plus, with TMS, you can directly change 64 (100%) to desired level (eg, 3C for 60%). It is not as simple for FLE. This is for my F015:
  • DRL_Idx: 01 01 0A 01 01 01 01 01 01 0B
  • POLI1_Idx: 01 01 0C 01 01 01 01 01 01 0B
OA hexadecimal is 10 decimal, but actual intensity is 64 (100%) as found in 3005.
      09-07-2017, 03:56 PM   #12
Almaretto
Almaretto's Avatar
2374
This may help explain architecture.
      03-28-2024, 01:37 AM   #13
abhaygujar
Drives: bmw f15
Hi
I hv G30 adaptive led headlights.
I wish to reduce intensity of my front led drls to 20% only while headlights on or off.
Can you pl guide, which parameters i need to change in FLE or any other module.
Also I wish have tail lights as drl. How to code?
Thank you
Abhay gujar
f80post
