      11-30-2020, 03:24 PM   #1
Dawgz
2022 M4 Comp Xdrive
1016
Drives: 2022 M4 Comp Xdrive
Turbo sizing for Heat shield
Im trying to figure out what the Turbo size is so I can order the correct heat shield for the turbos.
DEI shows the following chart, does anyone have the measurement on hand?
      11-30-2020, 07:26 PM   #2
S.W.G.
Drives: 2009 335i, X5 35I, 2012 X5M
Unless something has changed, Pure Stage 2 maintain the same casting/OEM size and just up the compressor/exhaust wheel size with some mild porting. Dont think you'll need one.
      11-30-2020, 09:10 PM   #3
Dawgz
2022 M4 Comp Xdrive
1016
Yea, I know they mill and modify stock cores. Just don't know the size as I haven't taken the stock one off yet. I guess I'll know when I remove it
It will definitely benefit from the shield tho...these things emit so much heat.
      03-04-2021, 08:18 AM   #4
ahnguyen
Drives: E92 M3
Did you ever figure out what size to get?
      03-05-2021, 10:02 AM   #5
Dawgz
2022 M4 Comp Xdrive
1016
Yea these are T2 turbos by size. Very little if any support for the specific ones we have due to the wastegate placement.
      03-05-2021, 11:40 AM   #6
Thecastle
Drives: F10 550i
2020 BMW M340i  [0.00]
2019 RAM 3500  [0.00]
2020 BMW X3  [0.00]
2016 BMW 550i  [0.00]
2000 Ford F450 7.3l ...  [0.00]
PTP makes a turbo blanket specifically for the X5M. I have it on mine and it fits quite well, and insulates very well.
      03-05-2021, 12:03 PM   #7
Dawgz
2022 M4 Comp Xdrive
1016
Don't like those, keeps the heat above the cylinder walls in the valley of the engine.
      03-05-2021, 12:18 PM   #8
Thecastle
Drives: F10 550i
2020 BMW X3  [0.00]
Not by my measurements. The blanket covers the sides and top of the exhaust housing on the turbos. The heads are shielded by a radiant shield and the turbo blanket. The underside of the turbos in the engine valley have another heat shield same as before. The under hood temps are significantly reduced and the engine temps on the sides are as well. Which is what I suspect your after. there is only wrapping/coating, trying to make a generic blanket fit or PTP.
These are the right product for everyone and after a year of use I can't say its really made any differences other than significantly lower under hood temps and possibly helping the lines over the top of the engine live longer. I also run without the noise cover.
I have thread on this, with measurements/pics, too lazy to find it at the moment. I did checks before and after with a heat gun, no temp increase in the engine bay anywhere checked, including under the turbos shot where the oil lines feed in. I am also running a low temp thermostat, and heat shielding on all the lines in the turbo area.
      03-05-2021, 12:34 PM   #9
Thecastle
Drives: F10 550i
2020 BMW X3  [0.00]
https://f10.m5post.com/forums/showthread.php?t=1580001
Some PTP fitting pics and temp differences and warning about turbo blankets and cheap down pipes.
      03-06-2021, 02:43 AM   #10
Dawgz
2022 M4 Comp Xdrive
1016
I think I'll just either ceramic coat the hot side of the turbo or get those individual t25 shields. I think with the blanket the heat has no where to go as it covers even the back side over the downpipes a bit as shown in the pic in the link you posted.
      03-06-2021, 09:54 AM   #11
Thecastle
Drives: F10 550i
2020 BMW X3  [0.00]
I can't say how well executed any of these really are for performance as that wasn't my goal. My goal was to reduce under hood temps as much as possible to keep the plastics from degrading. I use my X5M as a tow vehicle so the engine lives under constant boost and high loads and long stretches' of full throttle are not uncommon on grades, which produce a lot of heat. I was also after a bit quicker spool for the turbos, and maybe a reduction in limp mode's from low boost. All I can say is with my infra red thermostat, it really worked. The car is in for service at the moment so I can't take any new measurements (power steering groaning and leaky injectors).
I'm pretty convinced that turbo blankets of any kind are a good idea. But I think your concern of trapping heat in the block is legitimate, as 1000+hp, M5's have had problems with damaging the back to cylinders.
