Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Spacers advice/recommendation
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      02-28-2024, 11:27 PM   #1
nikokami
FBE (Fellow Bimmer Enjoyer)
Drives: 2011 BMW 328I Msport
2011 BMW 328i  [0.00]
Need help finding spacers that would work best with my car. I am not planning on lowering it as it came with the msport suspension and it sits at a good height for me. What size spacers do you guys think I should get? links would be appreciated. Photo attached
      02-29-2024, 06:59 AM   #2
Lone_Wolf
Drives: E91 325d@250ps/500nm MT
15mm works for me in my e91 m sport, not linking any shops Im on different side of the world ;-)
      02-29-2024, 03:58 PM   #3
mattanderson
Drives: 2007 E92 328i
I run 12mm on my stock 18's at all 4 corners for a nice OEM+ look.
15mm would fit but look less OEM, IMHO.
If you're running stock front camber, I'd say 15mm is a bit too aggressive up front.
      02-29-2024, 06:01 PM   #4
vester86
Drives: BMW 330D '08
it ALL depends on the specs of your current rims....
if they are original for an e90 LCI then 10mm front & 15mm rear is a pretty safe bet.
      03-04-2024, 08:45 PM   #5
whyzee125
Drives: Dinan stage 2 335i
I ran 15f/18r on my previous e90. Mine had style 162s so not the same wheels but they looked about equally sunken before the spacers and here's how it looked after.
      03-05-2024, 12:24 AM   #6
petrvales22
Drives: BMW E90 320i N46B20B
I tried 15s an they are good but I’m lowered so in the rear there are some little sratches to wheel arch. OEM wheels rear 255 front 225
      03-13-2024, 01:30 AM   #7
iroblesui
iroblesui's Avatar
Drives: 2010 328i
2010 BMW 328i  [9.50]
I run a 12mm front spacer and no rear spacer, I’m on ST XA coilovers with dinan front camber plates, no rubbing issues at all. 18x9 front wheels 18x9.5 rears with a 235x40 front tire and a 265x35 rear tire
whyzee1251680.00
72GMC81.00
Tags
e90, spacers
