Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Confirmation needed (18 x 9 on 265; square)
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      01-04-2024, 01:43 PM   #1
ky0u
ky0u's Avatar
Drives: e92 335i, f22 m235i, e30 325is
2015 BMW M235i  [0.00]
1988 BMW 325IS  [0.00]
2007 BMW 335i  [0.00]
SOLVED: read updates for resolution.
Hi all.
I'm looking to verify the specs on a new set of wheels but I lose confidence to finalize purchase, as I keep finding variations in people's experiences, even with very similar if not the same set up as my own car. Wondering if anyone can provide confirmations.
CAR:
Pre-LCI(04/2007) e92 335i
Current Suspension: Bilstein B12, M3 front CA conversion, alignment pin removed.
Current wheels: OEM 19" Style 313 (19x8 on 235F/ 19x9 on 265R)
Camber: -1.4 square
New wheel Specs targeted:
18x9 square; 265/35
Will I have any rubbing or clearance issues with this?
Notes:
I've previously run 275's in the rear without any issue. On this set up, I still had potential to run 10mm spacers all around without contact. (however, I've run into quite a few posts from others where 275s caused rubbing. This type of discrepancy is my concern)
I would ideally like to avoid running 255's on 9" if possible, as I had pretty high risk for wheel damage when I ran the stock 255s on the OEM 19x9 rear. I'm sure risk is slightly minimized with an 18" as the sidewall is taller but unsure by how much
Update EDIT:
Installed the new wheels and tires on my car. I was not as lucky as some that were able to run 265s without modification, but a set of camber plates sorted it out perfectly for me.
Below are the details, I'm running a square set up now after upsizing the fronts
Wheel set up: Apex VS5-RS; 18x9 et 30
Tires: Michelin PS4S 265/35/18
Suspension update: Added TMS camber plates
Alignment notes: I'll still need to get my alignment formally done so I'm not 100% sure what camber is at now, but it fully clears under compression.
The plates are supposed to add -1.75 over stock BUT I also maxed out positive adjustment on the shock tower when I reinstalled everything.
With my M3 CAs, I should theoretically be somewhere between -2.5 to -2.7 as she sits now, but I won't know for sure until i get it to an alignment shop.
Update 2:
Came in with the car at -2.6 in the front from the newly installed parts and my previous dirty alignment
Final Specs:
Front: -2.8; 0.24 total toe in
Rear: -2.1; 0.32 total toe in
IG: @lolhpfp
Build Thread
      01-05-2024, 08:51 AM   #2
rothwem
Drives: 2009 BMW 328i Wagon
2009 BMW 328i  [0.00]
You're going to have trouble making that fit up front.
ky0u1067.00
      01-05-2024, 11:34 AM   #3
mattanderson
Drives: 2007 E92 328i
It sounds like OP will need more front camber, at least.
ky0u1067.00
      01-05-2024, 05:37 PM   #4
ky0u
ky0u's Avatar
Is it contact to the fendr that’s an issue? I was originally aiming for an offset that would maintain the same position on the inside of the wheel and simply push the face outward. But I only have about 10-15mm of space, pushing out by an inch is about 25mm.
Is there enough room between the suspension and inside face of the wheel to make up the difference in clearance?
Also, those running 255s on 18x9 wheels, do you have any pictures of your sidewall profile / stretch as it sits?
IG: @lolhpfp
Build Thread
      01-06-2024, 09:51 AM   #5
whyzee125
Drives: Dinan stage 2 335i
If you go with a somewhat rounded tire like a Conti DWS or Firestone Firehawk Indy 500 I think you'll be just fine. Worst case, you'd need to add Dinan camber plates. I have 18x9 et30 with 255/35 up front with Conti DWS and have loads of room. 5 more mm on either side wouldn't cause me any problems.
      01-10-2024, 03:34 PM   #6
72GMC
72GMC's Avatar
Drives: 2006 BMW 330i
I just put on 9x18 ET26 wheels.
Quick test drive in the snow proved no rubbing so far.
Winter tires are 235/40.
I plan on 265/35 when summer comes.
I'm lowered, but I have -3 front camber and -2 rear camber.
      01-12-2024, 08:59 AM   #7
RealJ22
RealJ22's Avatar
1039
Drives: E92 CT200h Cayman Boxster RC
I think you might want a little more width for stretch. We had a customer with a pre-lci sedan running 265 all around.
Long Beach Blue E92 with Carbon Fiber Roof
Build Thread
      01-14-2024, 05:29 PM   #8
N54MPower
Drives: Fast Cars
Originally Posted by ky0u View Post
Hi all.
Pre-lci (04/2007) e92 335i
Suspension: Bilstein b12, M3 front CA conversion, alignment pin removed
New wheel Specs targetted:
18x9 square; 265/35
Notes:
I've previously run 275's in the rear without any issue. On this set up, I still had potential to run 10mm spacers all around without contact. (however, I've run into quite a few posts from others where 275s caused rubbing. This discrepency is my concern)
I would ideally like to avoid running 255's on 9" if possible, as I had pretty high risk for wheel damage when I ran the stock 255s on the oem 19x9 rear. I'm sure risk is slightly minimized with an 18" as the sidewall is taller but unsure by how much
Without stating a specific offset for the 18 x 9 wheel, any conversation about whether or not it will fit is based on speculation.
As stated elsewhere, 18 x 9 +29 or +30 will easily accommodate a 265/35 tire in most cases up front and in the rear.
I run square 513M front F80 wheels, which are 18 x 9 +29 and 255/35 Michelin Pilot Sports All Season tires. I use a spacer in the rear with those sizes, and I have enough to go with a 265/35 tire if I want.
      01-24-2024, 10:20 AM   #9
ky0u
ky0u's Avatar
This is super reassuring to know, thanks for the insight
when I started the thread, I knew I wanted 18x9 ideally, but needed confirmation of if it was even possible, and if so, what offset would make it work. that’s why I hadn’t included offset in the OP
I ended up grabbing a set of 18x9 et30.
Going to mount this weekend, hoping the slight geometry change from m3 CA conversion doesn’t add it’s own set of issues
      01-25-2024, 09:31 PM   #10
mattanderson
That's perfect and the M3 arms will help fitment.
      01-29-2024, 03:32 PM   #11
72GMC
72GMC's Avatar
I'd like to change my answer.
Some rubbing against the vented shield of 335-style oil cooler, front passenger wheel well. It only happens in reverse, under full steering lock.
wrevilo23.50
ky0u1067.00
      02-02-2024, 01:04 PM   #12
72GMC
72GMC's Avatar
Can also confirm that there was no rubbing when wheels were first mounted. Diagnosed as a result of spirited+ (jack@$$) driving on frozen snow-covered lake. Solveable.
ky0u1067.00
      02-05-2024, 11:36 AM   #13
whyzee125
Mine's the same way. 18x9 et30 Apex wheels with 255/35r18 and I rub the fender liners on both sides just slightly at near full lock. No rubbing on the fenders, bumper, or mounting bracket.
      02-09-2024, 11:45 AM   #14
ky0u
ky0u's Avatar
Thanks for all the information provided!
Went ahead and got my new set up on, ended up having to make a slight additional adjustment.
Gonna update the OP on this thread for easier reference in case anyone needs it in the future!
IG: @lolhpfp
Build Thread
