Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > 666m wheels on e93?
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      09-13-2023, 01:27 PM   #1
N54MDBL
Drives: 2013 335is Convertible 6MT
666m wheels on e93?
I found a killer deal for genuine 666M wheels (20” staggered - 9 ET29/10 ET40) with Michelin PS4S 265/30/20 and 285/30/20. What would I need to do to make these fit my 2013 335is e93?
      09-14-2023, 04:26 AM   #2
marconi118
Drives: 06/07 e93 335i
Put the 265 30 20 tires on the rear wheels
buy 235 30 or 235 35 tires for the front
front wheels have ET29 they stick too far out, 235 is the max you can put there
285 30 20 on the rear may fit but you have to shave the fenders where they meet the bumper
      09-14-2023, 04:33 AM   #3
marconi118
to fit 265 on front with ET29 is nearly impossible even with fender shaving
I run 245 had to do serious fender shaving.
tires ad08 run wide
on the rear if you shave a bit 285 should fit easily, I run 305 on 10X19 ET 40 M4 wheels
ET40 is optimal for the rear it leaves you the same space at the inner and outer side of tire
in front ET40 would allow you to run the 265 or even 275
      11-01-2023, 05:15 PM   #4
N54MDBL
tires ad08 run wide
Thank you! I didn't end up going with the 666Ms and am now on the lookout for 788Ms. The offset you mentioned matches perfectly with the 788s. I see a couple of them available on the classifieds, but don't have the history/posts to send PMs yet.
      01-20-2024, 08:29 PM   #5
Onizukachan
Great Teacher
Onizukachan's Avatar
1088
Drives: 06 e91 325ix
2006 E91 325ix  [10.00]
2006 Mini r53 JCW  [0.00]
2005 Mini r53  [0.00]
Alzor 19” are clones of the 19” CSL front 666m.
And when they do the buy 3 get one or 25% off sale at ECS they are $750 for the set.
Had a square set on my f31d Msport (et33). They looked great, flush but not hella flush, jsut 2-3 mm tucked. Did have one small imperfection on clear on one of them I noticed when I was ceramic coating them before tire installation, but one only I ever noticed. otherwise looked just as as good as friends m3 with real 666m, and Just as much work to keep clean.
You won’t fit real 666m on non M 3 series /non wide body or wheels similar unless you like the stanceypants/mxipoke look with no real tire to speak of.
They are a commitment,
Think handwashing washing weekly, or every 200ish miles city with soft wheel brushes.p amd a bucket.
Edit: on ecs website they are featured on an e9x in the pics.
‘06 e91 manual 325ix BarriqueRot
over Terra (one of 1), Nav, Sport, L7
A few OEM+ mods:
MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come…
      02-10-2024, 12:37 AM   #6
LOW4LYF
LOW4LYF's Avatar
2163
Drives: E92 M3 & F85 X5M
https://www.e90post.com/forums/showthread.php?t=1527458
