07-31-2014, 05:29 PM | #1 |
Rep 521
Uprated Anti Roll Sway bars
Anyone looked into this?
I believe some, maybe all E70s have option of Active roll bar? I came across this company offering some chassis stiffening items for the E70 - http://www.ultraracing.lv/?lang=en&m....0%2006s1rma1s Even with KWv3s installed I wonder how much more out there is on offer in terms of chassis tweaks. |
07-31-2014, 10:41 PM | #2 |
Rep 994
Buying parts from Latvia? Hmm, want to make $10,000 a week working from home too?
That said, I like the idea of bracing, I haven't really felt a need for swaybars, even stock. The car is actually setup well from the factory with the OE bars IMO
08-01-2014, 03:05 PM | #3 |
Rep 521
Sure would be nice if some other tuning companies hop'd on this one, but seems choices are rather slim other than this Latvian brand. In the UK I certainly feel the need for less roll, wondered if anyone had any thoughts
08-01-2014, 04:32 PM | #5 |
Rep 521
Sure, 22s and KWv3s have improved things already. Though the lack of initial turn in and oversteer is something I want to get rid of. I've not tried too many settings over KWs recommended rebound and bump, but perhaps if someone has any recommendations I can give it a tweak.
08-04-2014, 11:18 AM | #6 |
Rep 994
The 22's have probably affected the turn in due to the high rotating mass. But you can minimize that a bit.
You can play with tire pressure, less in the rear by about 2psi to reduce oversteer. Camber up front is adjustable, so you may want to make sure you have around -1.5 to -2.0, the rears, I don't think are adjustable. Lastly you can change the rake of the car a bit too, but you'll have to get a new alignment. Technically there is an "ideal," setting for compression/rebound on a coilover based on the spring rate. Too high or low you get bouncy or wavy/oscillating like characteristics. People that say they "stiffened," their coilover for the track and back for the street are doing it wrong. :-P
08-09-2014, 07:39 PM | #7 | |
e36s54, e70x5d
151
Rep 1,723
08-10-2014, 12:15 AM | #9 |
e36s54, e70x5d
151
Rep 1,723
