      07-31-2018, 09:49 PM   #1
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
Resolved: Crankcase vent hose cracked...Cylinder 4 misfire on WOT
Hi all,
Recently i started going in to limp mode when flooring the truck. Every time it happens, i run the diagnostic and I'm getting Cylinder 4 misfire, nothing else. Had the injectors replaced 5k miles ago. Should i swap out the spark plug for that cylinder? Boost leak would cause the same cylinder to misfire consistently?
Let me know what you guys think.
Thanks
UPDATE
Hoses are all cracked and just falling apart. Any reason i cant mock up some hoses out of fuel lines and secure them with worm clamps? The oem hoses are the cheapest shit i've ever seen in my life. Was the quality of a 99 cent toy.
Resolution
I replaced the hoses with OEM parts as it was just too much of a pita mocking up the proper length. Easy process. Was 280 each for the 13717848152 and 60 for the hose that sits on top of the engine.
Misfire was caused by a faulty coil, replaced and its back to beast mode. It was actually shaking and running sloppy for a while. Gonna replace the other 7 this weekend. Took about 10 mins to replace the toughest to get to coil on cyl 4. Removed the coolant overflow mount and set it aside, did the same with the vacuum reservoir then flipped up the cap on the coil, put a screwdriver through the cap loop and pulled it out with medium force. Then jammed the new on in, plugged it in and pushed the cap down to secure.
Thanks for the advice guys, hopefully this thread can be a reference to others.
      07-31-2018, 10:03 PM   #2
greddy91
Drives: 2010 X5M
Start with just the coil - that will be easier and is just as likely to be faulty.
      07-31-2018, 10:16 PM   #3
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
Thanks, will do. I'm due for plugs as I'm at 55k as well. I'll swap coils 3 and 4 to see if the issue moves with the coil.
      08-02-2018, 06:14 AM   #4
Lunker325
Drives: E70 X5M / 991.2 C4S
Wow, I thought mine were bad when I replaced them last weekend. Mine were leaking and able to be spun from almost every joint.
From reading other threads on the CCV system, I believe the ribbed design of the OEM hose is deliberate and helps separate the oil, so the system may not work as intended with smooth hose. I’d defer to others more knowledgeable though.
'17 Porsche C4S Sapphire Blue Metallic / Bordeaux Red - Softronic tune - Soul Sport Cats - Soul Exhaust
'13 E70 X5M Black Sapphire Metallic / Bamboo Beige - Full Dinan Suspension - Dinan Exhaust - BPM Sport Tune - xHP Flashtool Transmission Tune
      08-02-2018, 10:44 AM   #5
greddy91
Drives: 2010 X5M
I read that they were actually just ribbed for her pleasure.
      08-02-2018, 08:24 PM   #6
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
I bit the bullet and replaced all hoses for $600, dealer near me had them on hand.
      08-02-2018, 08:27 PM   #7
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
Thanks greddy91, it was indeed the coil. Replaced and it's running like a beast now. Took literally 10 minutes.
      08-02-2018, 08:38 PM   #8
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
Did you replace all hoses?
11157589989
11157589993
and the ducts?
13717848152
      11-12-2020, 03:45 PM   #9
chris604
Drives: X5 M
Hey. I keep getting the misfire on cylinder 6 on my X5M E70. installed new coil a year ago, as I thought it was from the coil. made no difference, replaced all vacuum hoses (4), then it worked for a while, now it's kind of bad, I cant really go up a hill or do anything but baby it. You think it's the coil again? Like how much are the good coils that I need to get? Mine cost about $100 like a year and a half ago. Or could it be some other broken piece of a hose somewhere that I cant see?
      11-12-2020, 03:52 PM   #10
chris604
Drives: X5 M
Also, what are the location of each of the cylinders on the X5M motor? I forgot how that went, and I may have changed the wrong coil?
      12-16-2020, 10:50 AM   #11
dlucas589
Drives: '19 X5 40iMSpt, '20 X7 40i
chris604 Did you ever resolve this? I have the same exact problem on just Cyl 6.
      05-07-2023, 05:38 AM   #12
Reg1
Drives: 2012 BMW X5m
E70 X5m PVC Valve Replacement
Hey
I've tried replacing the two pvc valves on my 2012 X5m but cannot get to the two torx bolts under the intercooler pipes. Any suggestions? Do i need to remove the intercooler pipes that feed the turbos to get to these two bolts?
Cheers:
      05-07-2023, 11:38 AM   #13
Colodano
Drives: 2010 X5M
Removing the center plastic pipe housing is the easiest way, I did it once with a small bit taped to fit snug in the end of a wrench, but it took ages. Good to get better silicone hoses and better clamps on those boost lines as well I think.
Oh, and you dont have to remove the diverter valves, just unplug the connectors and hoses.
