      05-02-2017, 05:05 PM   #1
rji2goleez
Drives: 2013 BMW 528xi
5 flash turn signals
I'm using Carly for BMW and trying to code my one touch turn signals to give me 5 flashes vs 3. I've changed the one touch and all the 'key' (1-4) to five flashes and get a successful coding message. However, I don't see the 5 flash option in iDrive (only 1 or 3 flashes).
Thoughts?
      05-02-2017, 05:11 PM   #2
dpie
dpie's Avatar
Drives: X5M
Thoughts?
Once coded to 5 blinks, the idrive setting becomes obsolete. Just leave it as is.
      05-03-2017, 08:14 AM   #3
omgboost
Drives: 2012 X5 35i
use the blinker and see if it flashes 5 times
      05-03-2017, 10:31 AM   #4
getafewlives
Drives: 2007 335i
Genius.
2009 BMW X5 - 4.8 - M Sport - Premium
      05-04-2017, 08:57 AM   #5
rji2goleez
Well of course, I tried that! I only get 1 or 3 blinks. iDrive setting works no differently. Set it to 1 and I get 1 blink, 3 gets me three blinks.
      05-04-2017, 09:26 AM   #6
rji2goleez
Well, I just redid the coding and it worked! Not sure if this was the difference but in iDrive I made no changes as indicated above. Thanks for the tip!
      05-04-2017, 09:26 AM   #7
omgboost
Drives: 2012 X5 35i
Don't remember the specifics but I changed mine to 5 flashes in Carly as well. Mine flashes 5 times. Didn't touch any idrive setting. Maybe try it again with Carly by switching it back to 3 and then 5?
      05-04-2017, 11:14 PM   #8
NoQuarter
Drives: 2008 535xi / 2011 Z4 35Is
2018 BMW X2  [0.00]
2008 535xi  [0.00]
2011 Z4 35is  [0.00]
If you touch the I drive setting you will get 3 again because that is the menu option in the display.
Carly is not changing the I drive menu option so it is kinda pointless as soon as you have another adjustment to make such as turning off DRL when working on the car.
