      04-11-2017, 12:37 PM   #1
socale39
Drives: 04 545i SMG
Those with H&R 2.0" Drop - Need Measurements
I've run a few different setups on my X5 and I've been documenting my progress and measurements on each drop. I'm considering switching up to H&R this time and while I have the measurements for the 1.2" drop, I haven't found any for the 2.0" drop.
Can someone post up their measurements from the floor to the bottom edge of the fender flare and post your results?
Thanks in advance.
      04-11-2017, 01:39 PM   #2
Googone20
Googone20's Avatar
176
Drives: 2015 X5, 2007 M6
I should have results on my X5 very soon. I may even be able to get them on this weekend.
2015 BMW X5 35d Msport Carbon Black/Mocha Nappa
2013 Cadillac Escalade Platinum Diamond White Pearl/Cocoa
2007 BMW M6 Sapphire Black Metallic/Black
2005 Ninja 636 Lime Green
      04-12-2017, 01:12 AM   #3
N62B48
N62B48's Avatar
22
Drives: XDrive 4.8i
hope these helps?
https://xoutpost.com/bmw-sav-forums/...lots-pics.html
      04-12-2017, 08:07 AM   #4
socale39
Drives: 04 545i SMG
Yeah I saw that thread the only issue is that those measurements aren't "settled" measurements so I'm sure it dropped a little more.
      04-13-2017, 03:57 AM   #5
UnicornM
UnicornM's Avatar
Drives: M
Get the KWs already lol
      04-13-2017, 07:01 AM   #6
socale39
Drives: 04 545i SMG
Frankly, if I were going to spend $2-3k on the KW setup I'd consider an air ride setup for a little more not to mention it would also be better for towing. However, I'm really not in a position to drop too much as we are building a house right now.
      04-15-2017, 09:15 PM   #7
Googone20
Googone20's Avatar
176
Looks like Tire Rack screwed me over. Went through all the trouble of installed mine and such, and I am pretty sure they sent me the 1.2" kit. My front height is at 30.25". They ride awesome, but I do wish it sat a little lower. Now I am pissed, and not sure what to do. It's not like swapping the springs is a small or quick job.
      04-16-2017, 01:41 PM   #8
UnicornM
UnicornM's Avatar
Drives: M
Air ride will cost more like $7k+
      04-16-2017, 02:15 PM   #9
socale39
Drives: 04 545i SMG
Yeah for top shelf parts and install. Air ride system can be easily had for half that cost based on what I've been looking at. $1500 for the air struts, $1000 for air management and another $1000 for pump, lines, tank, etc. I would just need the basics so no need for all the fancy iPhone controlled systems. I could see where a lot of cost would come from install but I'm a pretty handy guy so that's a cost I wouldn't incur.
      04-16-2017, 03:40 PM   #10
Googone20
Googone20's Avatar
176
Yeah, I can't see a solid system costing me $7k if I do the install. I haven't even looked into it yet though. I have only had my X5 since Thursday, so I think I am moving pretty fast already. I'll post my progress in my build thread tonight.
      04-16-2017, 07:03 PM   #11
socale39
Drives: 04 545i SMG
I say run with your setup for a while then reassess if you want to go lower once you have the wheels installed.
      04-17-2017, 03:10 AM   #12
UnicornM
UnicornM's Avatar
Drives: M
What air struts are they?
Still I'd run KWs over spring setups, but each to there own.
      04-17-2017, 10:02 PM   #13
socale39
Drives: 04 545i SMG
D2 has a setup. I'm also waiting to see if BC Racing will make an E70 coilover setup with a bag option. I was very impressed with their coilover setup on my E60 M5, more so than the KWs.
      04-21-2017, 09:10 PM   #14
bmdubbayoo
Drives: LBBM/Aragon F85
That would be awesome. I have BC Racing coilovers on my E36 M3 and they handle and feel perfect.
      04-21-2017, 09:16 PM   #15
Googone20
Googone20's Avatar
176
I wonder if BC would make a run of them if we put a group buy together? Has anyone tried to contact them and look into this?
      04-21-2017, 11:20 PM   #16
socale39
Drives: 04 545i SMG
I contacted them last year and they said they had plans to make a coilover system but no eta. I just sent over a follow up email to the contact I was communicating with to see if this is still on the table or not.
      04-22-2017, 12:28 AM   #17
Googone20
Googone20's Avatar
176
Sounds great. I would definitely be interested in a set. I had them on my F30 328d Msport, and they were great. I will say it took some time for me to get them set up properly on the car, but they rode great as daily drivers. I had them set very soft for comfort.
      04-22-2017, 06:41 AM   #18
socale39
Drives: 04 545i SMG
I'm not sure about you guys but I felt the BC coilovers seemed to have responded more to the adjustments compared to KWs.
      04-29-2017, 08:24 AM   #19
socale39
Drives: 04 545i SMG
Googone20,
Has your drop settled at all?
      04-29-2017, 04:15 PM   #20
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
I'd post my measurements but I think I blew a strut out since the bottom of the truck is covered in fluid and the fender is almost sitting on the tire. I had BC's on my E53 and they were great, I'd written BC about a year ago for the E70 X5M and they had nothing at the time.
      04-30-2017, 01:46 PM   #21
Googone20
Googone20's Avatar
176
I am sitting right around 30-30.25" all around right now. It settled slightly more, and I have been playing with the rear ride height. I like
the rear even with the front.
Here is a current picture of it.
