      09-21-2014, 05:02 PM   #1
Joyaant911
Drives: 2007 x5
Reverse knocking noise
I'm getting a knock/thud every time I put the car in reverse and back up about 5-10 feet... Same thing happens when going back forward but less often... Also I have a ticking noise while driving can be heard with windows down and it's pretty noticeable, no idea what that is either just recently started.. If anybody has experience with this please shed some light
      09-22-2014, 06:04 AM   #2
captain_tiberius
Drives: e90 323i/e85 Z4 3.0i/e70 X5 35
I had this issue once with my previous X5. It ended up being the transmission after several attempts to stop the sound at the dealership. A new transmission is in order possibly, but It could be something else...
      09-22-2014, 11:27 AM   #3
serge1
Drives: X5 35d
2011 BMW X5 35d  [0.00]
Sounds like driveshaft or CV joint. You can even check it yourself by getting under and trying to shake. Rubber may have worn, lubrication washed off and there you go.
      09-22-2014, 08:45 PM   #4
Joyaant911
Drives: 2007 x5
I changed center carrier and guibo wit OEM replacements the sound has been there even before changing started like a week before I replaced them my old guibo was torn to shreds. Not sure what's wrong I also have a lingering vibration at 40mph I've replaced almost all. Front suspension components with no luck
