      01-18-2020, 05:56 PM   #1
Lviv777
Drives: f30 330e, C8 Vette
Steering problems
Was driving up a few mountains and got throw to the side lightly, pulled out and the steering at standstill is pretty much locked impossible to move, as soon as you get going it gets lighter and almost back to normal unless you turn it sharply, and overall it feels more wobbly. Any ideas on what it could be? Bad power steering pump? Thanks
EDIT: Its a bad power steering pump. Going to get an estimate to see how much it will cost. N55 btw.
      01-18-2020, 07:19 PM   #2
TwinSnailz
TwinSnailz's Avatar
75
Drives: 2011 X5//M
Did you look in the fluid reservoir to check the status? Full, foaming, bubbles
      01-19-2020, 11:45 AM   #3
Lviv777
Full no foaming or bubbles. Confirmed today its a bad pump. Anyone know what an average replacement costs?
      01-19-2020, 02:39 PM   #4
pdX5M
pdX5M's Avatar
Drives: E70 X5M
2013 BMW X5 M  [0.00]
About $1400 on ECS Tuning site. May be able to find cheaper elsewhere. If it were me I'd be figuring out how to DIY this if possible. The dealership will surely bend you over to get this repair done.
https://www.ecstuning.com/b-genuine-...p/32416799278/
Edit: here's the diy from newtis. Doesn't really look bad... https://www.newtis.info/tisv2/a/en/e...upply/CvOcCLwg
- 2013 X5 M - Silverstone Metallic w/ Black Perforated Complete Merino - All OEM Options - 12.5mm/20mm Spacers - Velos Stage 2 - xHP Stage 3 - AA Catless - Megan Racing Supremo - PTP Blanket - K&N Drop In -
      01-19-2020, 05:17 PM   #5
Lviv777
Thats a surprise so far I have found ones much cheaper. https://www.ebay.com/itm/Power-Steer...W%7CModel%3AX5 I am guessing the one I found is the wrong one. The labor cost doesn't worry me as much as the part. $1400 is pretty steep for a pump.
      01-19-2020, 05:21 PM   #6
pdX5M
pdX5M's Avatar
Drives: E70 X5M
I just pulled the part number off Real OEM. I'm sure you can find one cheaper than $1400 but that's just the first one I found on a quick Google search for the S63 motor. There's three different part numbers and I searched the newest one.
      01-19-2020, 05:44 PM   #7
Lviv777
My bad, I should have specified I have the N55. Sorry about that!
      01-19-2020, 05:46 PM   #8
pdX5M
pdX5M's Avatar
Drives: E70 X5M
Gotcha. For some reason I had it in my head you had an M. In that case I'm guessing you should find a pump much cheaper 👍🏼
Lviv77741.50
      01-21-2020, 04:20 PM   #9
Lviv777
$575 and two days and the car is done! Wasn't as bad as anticipated.
Nyc Dito112.50
pdX5M111.50
