      01-15-2020, 10:20 AM   #1
pearlpower
Drives: 2013 328i
X5M Blackstone results
Attached. I do seem to have a bit more fuel than I am comfortable with. I am going to change out the oil at 4k and resubmit. Since their fuel analysis is not known to be very accurate....I will keep an eye on it. Piece of mind goes a long ways so I might just go ahead and change out the Rev 12 injectors. I also changed the oil after the vehicle was sitting for a week, but ran it for 5 minutes only. Generally I run it longer before changing oil, but wanted to gauge any injector leaking.
My CCV pipes were leaking, but am doubtful they had any impact on these results.
Specs: Mileage 105k
Oil Liqui Moly 5w-40. I generally run 5w-30, just had a few jugs of 5w-40 lying around.
MotorKote additive
      01-16-2020, 07:43 AM   #2
philly42
Drives: X5M, Z3M
It's likely from not getting the oil temps past 200F before doing the oil change. Normally I mention to on the sample slip if the oil wasn't brought up to normal operating temps before the oil change.
If you have or know someone with ISTA program, there's a built-in diagnostic to check if the injectors are leaking.
      01-16-2020, 10:30 AM   #3
pearlpower
Drives: 2013 328i
I have INSTA and will have to check into it. It does not like my E70 much, my 328i connects no problem.
      01-16-2020, 02:53 PM   #4
philly42
Drives: X5M, Z3M
I have issues connecting whenever there's an automatic windows update. Seems that it resets the latency in the cable port drivers.
From what I remember the diagnostic will engage the fuel pressure and monitor the pressure for a duration of time to see if there's a pressure lost. I forgot how long it was for...probably a min or two.
