The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > Oil filter gasket leak? should I use UV dye?
      01-27-2024, 04:09 PM   #1
BMWandJo
BMWandJo's Avatar
Drives: Bmw e91 N43 2011 M-Sport 320i
Hello,
Does this looks like a familiar leak? Could it be oil filter gasket? Should I use oil Dye & UV to check?
PLEASE SEE PICTURES below.
My e91 320i 2011 133k miles. Just had rocker cover gasket and oil filter gasket done 10 month's ago.
I am learning the lessons hard way!
Had some work done at a cheap Garage with a mechanic who I don't really trust, but I was broke and it was cheap!
I would be grateful for your advice!
https://ibb.co/kgj6m3f
https://ibb.co/tBFQyc7
https://ibb.co/z4BG0qn
https://ibb.co/S6sbG54
https://ibb.co/0QcfCt9
      01-28-2024, 02:58 AM   #2
Phil325i
Phil325i's Avatar
Drives: E92 325i MSport Coupe
Yes probably your OFHG or could also be the valve cover gasket...or both. Welcome to the leaky world of BMW!
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
      01-29-2024, 08:20 AM   #3
BMWandJo
BMWandJo's Avatar
Just ordered some Ring RLD4 dye 25ml, will put it in and hopefully locate where it's leaking from!
Also ordered some 5lt Oil and Mann filter kit, I'm guessing I'll need to replace OFHG but I want to confirm with the dye first!
