09-01-2012, 05:53 PM | #1 |
Rep 194
Drives: M5, i8, V10 R8 Twin turbo
X5 diet
Anybody know if you can remove the backseats with some ease in an X5M? Are you doing anything else at the track to lighten the load?
Thanks D
2014 M5 Comp, Dinan P1 708hp -- Daily
2015 BMW i8 Pure Impulse World 2011 Audi R8 V10 Spyder, Twin turbo, MAN PEDALS! Grave yard: 14 1100hp GTR, 11 Twin Turbo R8, 13 M5, 09 LP-560, 14 GTR, 08 R8 V8, 11 X5M 700hp, 10 E93 M3, 08 E92 M3, 06 E46 M3 CP, 02 E46 M3 |
09-01-2012, 09:24 PM | #3 |
e36s54, e70x5d
151
Rep 1,723
Really?
The e93m3 is heavier then the e60m5. As a matter of fact, it was the heaviest ///M ever, until the x5m came out. To the OP: backseats and rear cargo area panels are easy to remove and take some knowledge and careful patience to install again. However, at 5,200 lbs + you are going to feel very little difference after removing 100 or even 200 lbs. |
09-01-2012, 10:40 PM | #4 | |
Rep 194
09-02-2012, 04:48 AM | #5 | |
e36s54, e70x5d
151
Rep 1,723
Taking out the rear seats and rear cargo panels on ur X5M will maybe yield 100 lbs. max... and u will not feel that on a 5200 lbs car. I dropped 200 lbs. off my e46m3 and felt it at the track by 2 seconds = 3200 lbs. But when I dropped 200 lbs off my e90m3 i only gained 5/10ths at the track = 3400 lbs. Weight at the track works exponentially after a certain number and it has to do with change of direction/inertia. A GT-R doesn't start getting faster until you drop down below 3600 lbs. so oddly enough a 3700 lbs. GT-R will go as fast as a 3900 lbs. version. There is not a scientific calculation to this, but I would assume you would have to lose at least 400 lbs to feel or see any difference on the timesheets. |
09-02-2012, 07:34 AM | #6 | ||
Rep 194
I will see how the new parts go and let you know. Thanks for the info. D
