      08-29-2017, 02:42 PM   #1
kurtisss
Drives: 2010 X5M
2010 x5m blow off valve
any way we can change or ad a blow off valve so i can hear a pssshhhhh when it shifts?
      08-29-2017, 05:39 PM   #2
greddy91
Drives: 2010 X5M
You already have them - diverter valves. You will find that they are vented back into the intake though (a common function).
I believe you can still find this guys post on the forum. As I recall he experienced some odd driving characteristics when vented to the atmosphere.
Keep it classy!
      08-29-2017, 07:13 PM   #3
jcm3
Drives: F85 X5M, 07 911 TT
You can here them if you install intakes
      08-30-2017, 09:26 AM   #4
windsailor
windsailor's Avatar
Drives: 2013 X5M Black Saphire
Would this be comparable to those Subarus, M Lancers and tall diesel trucks crying out for attention? mmmhhh
      08-30-2017, 11:44 AM   #5
TheVazha
Drives: X5Mmmkay.
I've been exploring this also. It would add just the thing this truck needs to make it the ultimate bad ass.
      08-30-2017, 01:42 PM   #6
kurtisss
Drives: 2010 X5M
thats what im talking about! thanks ill have to search for that.
Keep it classy!
      09-03-2017, 02:36 PM   #7
TheVazha
Drives: X5Mmmkay.
Can anyone link the original thread on this mod?
Maybe this?
http://www.xbimmers.com/forums/showthread.php?t=1042574
      09-07-2017, 07:32 AM   #8
Cr4ck_x5M
Drives: 2011 E70 X5 M
I was looking around and found these. Go fast bits DOV, Another X5M owner on instagram told me. "The screws that came with the DV would not work. So I matched up the factory screws with "Tapcon" screws. Worked perfect. They have the blue heads." Idk if they make the swoooosh! Sound tho.
      09-07-2017, 08:49 AM   #9
Thecastle
Drives: F10 550i
2020 BMW M340i  [0.00]
2019 RAM 3500  [0.00]
2020 BMW X3  [0.00]
2016 BMW 550i  [0.00]
2000 Ford F450 7.3l ...  [0.00]
Nope, the DV+ is not a blow off valve. Its just a billet diverter valve, for cars who are running higher boost and want a more reliable replacement to the rubber diaphragm DV's that can tear from increased temps when running turbos outside their efficiency range (typical tuned car).
I've actually had one of these and run it on my 2011 GTI with K04 turbo. It works fine, but is not a BOV.
P.S. Atmosphere venting of boost (blow off valve) reduces performance and increase lag all with the added benefit of additional noise? Why not just get a cheap bluetooth speaker and wire it into your OBD port and run a raspberry pi to watch for shifts and then it sends a sound through the BT speaker. Might be cheaper and it won't hurt performance.
      09-07-2017, 10:46 AM   #10
greddy91
Drives: 2010 X5M
Off topic, but that air filter placement is facking tarded. Ditch your stock attempt at cold air to pull in air from the absolutely hotter part of the motor... Brilliant! Would love to see before and after IATs on that setup.
      09-10-2017, 09:55 PM   #11
Cr4ck_x5M
Ya that's not my set up lol just pics I came across I run a RK set up on mine.
      09-10-2017, 11:18 PM   #12
TheVazha
Drives: X5Mmmkay.
Dude I've seen it done on other platforms and I'm amazed that people have the gall to call it a cold air intake. Have you ever lifted your hood after a long drive? It feels like you're staring at the sun. I feel bad for the motors that have this mod. The best part is when they say something like "cold air intake, only $1500!" Lol.
      09-14-2017, 01:12 AM   #13
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
Curious what his Instagram page is and/or if you can get him to come onto this thread and give more details. Go Fast Bits also makes a DV that has a vent to atmosphere feature as well.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
      09-14-2017, 01:14 AM   #14
m5james
m5james's Avatar
I agree that his filter placement is terrible. Too bad RK hasn't come down on price to move multiple units vs trying to make all their money off a handful of them. I've got a custom made intake and the BOV sound is awesome so I'm curious what could be done to add more.
      09-14-2017, 06:30 AM   #15
frankenm
frankenm's Avatar
96
Drives: 12' X5M, 99 M3
You will run rich if you convert or remove the bpv the intake system and computer account for the additional air flow coming ... would not recommend without proper tuning.
      09-14-2017, 06:40 AM   #16
m5james
m5james's Avatar
For like .5 seconds, basically the time it takes for the DV to recirc the air...while off throttle. I haven't tried it myself, but I can't imagine damage will be caused.
      09-14-2017, 08:54 AM   #17
philly42
Drives: X5M, Z3M
Where is the air meter for the S63? I recently pulled off the intake and don't remember seeing the MAF sensor around there. If the air hasn't been accounted for, I don't think there should be a problem blowing it out to atmosphere.
Resetting your adaptation might help the engine adjust to the new flow of air.
      09-14-2017, 08:58 AM   #18
philly42
Drives: X5M, Z3M
Wow, amazing work on the custom intake!!
m5james431.00
      09-14-2017, 09:29 AM   #19
m5james
m5james's Avatar
The S63 has no MAF, which has it's pros.
      09-14-2017, 09:34 AM   #20
m5james
m5james's Avatar
Thank you, sir...it was made at a shop in CA, loosely based off the stock design from the E70 4.8l with BMC #FBTW80-151 filters covered in K&N water stocks. While I haven't dyno proven their performance, they sound amazing...the GF just knows what I'm going to do in every tunnel now
      09-15-2017, 08:44 AM   #21
philly42
Drives: X5M, Z3M
Ahhh I've been looking at the engine detail for the S63TU and I see an air mass meter. So I guess that's one of the upgrades for the engine.
(Pic is for the S63TU, See #5)
      09-22-2017, 09:09 PM   #22
jandref321
jandref321's Avatar
345
Drives: 2012 X5M
It looks like they still use the stock diverter valve with the DV+ between. I wonder how this is beneficial or how it even works if you still have the stock DV on there.
