      08-19-2012, 12:52 PM   #1
CMH75
Drives: '11 X5 35d
Help...can't get brake dust off...
My 35d with the 20" wheel option just hit 37k miles and I've never had a problem removing brake dust off the wheels until today. I went 2 weeks between washes due to poor weather (which I've done before) and the brake dust was heavy (also been there before). After a wash, my wheels have always been spotless.
This time, I've washed my wheels 4 times using BMW's wheel cleaner gel and scrubbed like a crazy man; the markings appear to be literal stains on the wheel.....it is streaked all over the place. I'm calling out my detailer to see if he can help, but has anyone ever experienced this on BMW's wheels or know how to fix?
I was previously amazed at how slick they were and how easily it came off...this is my first experience with it being literally stained....
      08-19-2012, 02:43 PM   #2
NRG
NRG's Avatar
Russian Federation
36
Drives: 2012 X5 35d
Looks like too much acid was applied and you scrubbed it in removing the clear. Or you hit a puddle of paint thiner.
Retired: 2005 N52 E90 330i Sport 6AT
Retired: 2007 N54 E92 335i Sport 6AT
Current: 2012 M57 E70 X5 xDrive35D
      08-19-2012, 07:11 PM   #3
petercory
Drives: E93 M3, GT3, 930S
Install a set of Akebono Euro Brake Pads and you'' never have the problem in the future!!
      08-19-2012, 07:50 PM   #4
GKyri
Drives: 2010 X5 30D
There could be some oil/tar/grease mixed in there. Maybe a mild degreaser? Have you tried some car cleaner polish?
      08-19-2012, 09:26 PM   #5
CMH75
Drives: '11 X5 35d
Thanks for the input...haven't tried anything else yet. I'm stumped as to the cause, but I'm going to hold off until the "pros" can look at it later this week. I'm just hoping that what ever I did wasn't the fatal flaw to clean wheels.
      08-20-2012, 05:53 AM   #6
JL350
Australia
20
Drives: 2.0D X4
CMH75 that looks like some sort of oil and brake dust mix, water and soap etc seems to spread it. Try some paper tower with some silicon spray wetting it. Wipe a black spot and see if it moves it. WD40 etc can also work but silicon spray seems to work best.
      08-27-2012, 11:12 PM   #7
Drk280
Drk280's Avatar
Australia
22
Drives: 2012 F30
auto detail guy told me to wax the rims when they are very clean (or when you get your car new) - alternatively here in Australia a company Bendix still sell asbestos coated pads or white surface pads i think they are called like they used to use back in the 80's and no more dust on your wheels
      08-27-2012, 11:39 PM   #8
GKyri
Drives: 2010 X5 30D
Asbestos is banned in Australia, just like it is in most western nations. I think you will find that Bendix has a dustless pad that contains no asbestos.
      08-28-2012, 01:56 AM   #9
donho
Drives: 2014 E63s AMG
Looks like some kind of oil, smeared with brake dust.
I never had an issue with factory wheels. I run it into the car wash, ask them to scrub the wheels extra good and they come out great. and I have gone 1 month+ without washing.
In the beginning I hand washed the truck and the wheels are hell to clean. You cant get inbetween the spokes with a car wash sponge. After that, car wash only. They have a smashed bristle wheel brush that cleans all the tight areas.
2011 BMW X5 M-SOLD
1/4mile blast
2009 Mercedes E63 AMG-SOLD
2014 Mercedes E63s AMG
      08-28-2012, 04:55 AM   #10
rwilson
Drives: 2006 X5 3.0i 6spd manual
you may want to try something like simple green. I had the same issue earlier this year on my 214's when the front cv boot split and threw grease everywhere.
I normally use a daytona speed master wheel brush once a week and really dont have to wax/seal the wheels but once a year when I switch to the winter setip
      08-28-2012, 03:14 PM   #11
BabyCAP
BabyCAP's Avatar
Drives: bmw
This is very good info for all readers! Same happened to me. For a while I kept wondering why I could not keep my wheels clean. I had a tear in the CV boot. This type of grease on your wheels "may" be a sign to check CV boot. Can't hurt. Good Luck.
      08-28-2012, 08:48 PM   #12
AlBoston
Drives: 2019 740i xdrive & 2018 640GT
wow a lot of really bad suggestions! Don't use goo gone, simple green, silicone spray any of those!
Try simple automotive clay, remember these wheels are PAINTED just like your car is painted. I use armor all wheel protectant spray after I clean and dry my wheels and I can go weeks with virtually no brake dust buildup... really amazing stuff.
      08-29-2012, 06:29 AM   #13
rwilson
Simple green makes a product specifically for wheels. I mentioned it since my normal cleaner "Sonax full effect" was not successful at getting grease off of the wheels.
I think the issue here is abnormal grease not regular brake dust which most standard
cleaning techniques can handle.
Rich
      08-29-2012, 10:46 AM   #14
miller
Drives: X5 M
There are good wheel cleaner products out there that can deal with brake dust and tar build-up, I use Eagle One A to Z. It's good for any type of wheel (painted, chrome, polished, etc.). You should not scrub very hard with a brush as these are painted. Use a sponge. A mild degreaser (Simple Green) will not hurt your wheels and it may be needed if the black stuff is oily.
Once the wheels are clean, coat them with Armor-All Wheel Protectant. It will repel dust, road grime and tar. And it's good for about two washes before needing a re-coat.
      08-29-2012, 11:09 AM   #15
phx08
phx08's Avatar
Drives: MKV Jetta
I wouldn't use anything strong like goo-gone and things alike. Try to soak the wheels a little bit before trying to wipe. Also maybe use a soft brush to try to get the dust off.
      08-30-2012, 03:38 PM   #16
TwinturboGTR
Drives: E53 4.8is
So Sonax didn't take that stuff off eh??? Well for real stubborn stuff, I've used 3m General Purpose Adhesive remover. It is a solvent, but safe for CURED paint. So with the amount of miles you have, the paint should be good to go. Just get a microfiber towel and spray some on the towel and wipe. It will take that stuff right out.
I had the same problem on my 4.8is last week when I was prepping to go to Bimmerfest. Called up a sponsor detailer on my other forum (Xoutpost.com) and said that he uses the 3M all the time with no problems. Just gets tricky on BRAND NEW PAINT. But on yours, no problem.
Detailing clay may work, but if it is grease (While looks like it is and as other suggested from the CV boot) then the clay will just smear it around and won't pick it up as good or as quickly.
Hope that helps.
      09-02-2012, 11:53 PM   #17
midtowneast
Drives: 2012 X5D
1989 325i  [0.00]
2001 330xi  [0.00]
2012 X5 35d  [0.00]
Just a shot in the dark, I took my X5 to a newly installed touchless car wash that applies an armorall type product at the end of the wash. The car wash uses rollers that you drive through at 1 mile per hour. After the wash I noticed that the few brake dust spots left did not come off with the usual towel wipe. I cleaned the wheels after a vacation trip and had a tough time getting the dirt off and it looked like your picture. I used purple power a degreeser from walmart and two brushed to get the stubborn spots off.
      09-05-2012, 09:33 PM   #18
CMH75
Drives: '11 X5 35d
Thanks everyone for the input.....I was out of town for a bit, so I'll post again when I have a chance to address it and let everyone know what worked.
      09-05-2012, 10:18 PM   #19
jhilly8982
Drives: E70 X5
I would use some Iron X on it. Works wonders. Be careful though, spray only on the wheels unless you want to rewax your whole car.
