      06-03-2015, 10:13 AM   #1
boa1977
Drives: e90
Smile 2011 X5 Front Brake Pads
Hello,
My 2011 X5 front bake pads needs replacement. I have 48k miles on the x5 and its unfortunately its not under maintenance anymore. Any idea how much front brake pads and installation will cost? Should i get it through the dealer or outside? Any recommendations would be appreciated.
      06-03-2015, 12:21 PM   #2
mitch808
Drives: 2012 X5 35i
I just bought pads and a sensor for the fronts for about $75 from turner motorsports. (Centric PosiQuiet pads), as well as two front rotors from amazon for $40 each.
It took me an hour to change in my garage with hand tools.
You will pay 3x-5x what I paid at the dealer.
      06-03-2015, 04:02 PM   #3
boa1977
Drives: e90
This is the sensor you bought? I have a x5 35i
http://www.turnermotorsport.com/show...0i-e71-x6m-50i
      06-03-2015, 07:00 PM   #4
mitch808
Drives: 2012 X5 35i
they have a filter on their site to show you what fits your car.
      06-04-2015, 12:34 AM   #5
Flying Ace
Flying Ace's Avatar
4985
Drives: G05 45e, 997.1 & 991.1 GT3s
Rounded to the nearest dollar for each component based on the cheapest dealer online pricing:
$76 for front pads for each corner (x2) = 152
$98 for rear pads for each corner (x2) = 196
$3 for fluid per bottle (x) 2 = 6
$65 front rotor, each (x) 2 = 130
$113 rear rotor, each (x) 2 = 226
Total: $710 for parts
Indy shop labor would range between $400-$500 (just a guess, but can't be $1000 for a 4 hour job).
So let's say grand total of a brake job is $1200, sourcing it privately and having indy shop do this
      06-04-2015, 10:53 AM   #6
mitch808
Drives: 2012 X5 35i
That's insane that brake pads cost as much as they do at the dealer, let alone they charge individually. Really, when is it ever a good idea to change just one pad? Their rotor prices are not too bad and not all craycray pricing. :-)
Seriously though, this is a 1hr job per pair, budgeting 3hrs tops to change pads and rotors.
Fluid is something you do once every 1-2yrs based on driving habits. Often it's better done at a dealer, as there are times you need to cycle the ABS system.
      06-04-2015, 11:55 AM   #7
rennis
rennis's Avatar
43
Drives: E70 5.0 & B5 S4
2nd this - do it yourself, it's a cake job. Tutorials on youtube are easy to find.
Only handtool I didn't have was the correct 6 point/allen to loosen one of the carrier bolts on the caliper. If memory serves it's a 9mm bolt, which isn't a common size if you've got average joe hand tools.
      06-05-2015, 06:05 PM   #8
PAX5
Drives: 2012 X5 50i
Caliper carrier bolt is a special E-socket (star) #18. Don't attempt to do the job with a 6 point socket ... it will strip the bolt:
PAX5
BMWCCA 20645
      06-08-2015, 02:52 PM   #9
djrabbi
djrabbi's Avatar
Drives: G05 M50i
Any aftermarket recommendations? I feel like factory brakes aren't up to par or maybe just me? I drive my dad's ML and MDX, feels like the car stops where X5 takes a while to come to a complete stop
      06-08-2015, 03:59 PM   #10
mitch808
Drives: 2012 X5 35i
The centric setup I just bought is fine. The key is good bedding.
Your current pads probably need a good sanding on the rotors, and the pads rebed. Or just replace with new stuff and bed in properly.
      06-08-2015, 04:45 PM   #11
mweisdorfer
mweisdorfer's Avatar
Drives: 2007 Black/Black 335i e90
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
Akebono pads and new oem sensor like BOWA Might run you $90.00. Make sure you clean up the brake caliper sliding bolts and re-lube the casing they go into like:
wiCRC 05361 Silaramic Brake System Grease - 5 oz.
