05-27-2015, 07:00 PM | #1 |
Rep 191
X5M Having Trouble Starting
Hey guys, recently my X5M has had a strange issue starting.
When the car has sat for a while (a couple of hours maybe) it seems to take a bit of time to start. Like the starter is spinning just fine but it takes 2-3 seconds to actually catch and start up. I don't think it is the battery, but what voltage should the battery be reading both before cranking and during cranking? I have a multimeter and can check the voltage. Does anyone have any other items I can check? Thanks, Paul |
05-27-2015, 07:08 PM | #2 |
Rep 3,200
How's your exhaust tips looking?
05-27-2015, 09:09 PM | #4 |
Rep 44
Could be leaking injectors if the cranking start issue only show up after set for few hours but not cold start.
does it sounds similar like this ? Last edited by Zige; 05-28-2015 at 09:02 PM.. |
05-28-2015, 04:50 PM | #7 |
Rep 273
Injectors are a pain in the ass on these cars. The job is tedious and everything has specific torque specs. That and you have to program each new injector with the DME. When I pulled mine out to replace they look like they were swimming in oil.
05-28-2015, 05:33 PM | #8 |
Rep 191
05-29-2015, 07:36 AM | #11 |
Rep 41
05-29-2015, 09:58 PM | #13 |
Rep 273
I swapped a coil and sparkplug followed by clearing the cel i had. Once the lite came back on I looked at the service history and saw the injectors were never replaced.
Not sure if theres a way to check them but the drivers side is a little easier to get to as oppose to the passenger side bank. Forum member M3_guy's tip can point to faulty injectors with the darkening of the exhaust tips. |
05-30-2015, 08:44 AM | #14 |
Rep 1,206
mine went around 20K...Did they fix the issue with the injectors or are they always going to need replacement
I didn't know I couldn't do that. But I did know I couldn't do that.
05-30-2015, 10:01 AM | #15 | |
Rep 145
05-30-2015, 05:15 PM | #18 |
Rep 1,206
I have a 12 new injectors and I know others with a 12 and needed new injectors
05-30-2015, 05:17 PM | #19 | |
Rep 1,206
you did get 100k out of it!, I do 10k a year so I have 7 more years with the beast
05-30-2015, 07:36 PM | #20 |
Rep 145
I will check my old repair order there was a revision number on the injectors ...surprised BMW hasn't done a program like the N63 ...I had a good SA and he just sent email to BMW NA and that's how got replaced
