12-16-2013, 07:21 PM | #1 |
Rep 3,035
Drives: 2022 BMW X5
Engine oil at minimum!
Hi guys, own X5 for little over a month, 2011, 35i. Picked it up with little over 30k miles, currently at 31895. Got message tonight that my Engine Oil at minimum level and I need to add 1 quart of oil. Is this normal? Sounds like too much too soon to me. I called my sales rep. he also said that this doesn't sounds normal and advised me to call tech in the morning. Now I just went back to my car and check the status, no message about oil until I actually go to check oil screen, then it the same message. Overall status is still says good! I'm a little confused. Should I just add a 1 quart of oil as it says, I actually have no idea which kind of oil it's using. Can I still drive like that for some time?
Thanks for u time and responses! Edit: so I checked what kind of oil this engine uses and it seems like unless they put something different it's suppose to be: Castrol Full Synthetic 5w30 I live kind of far from the dealer where I bought my car so even if they tell me to bring the car in I probably won't be able to for few days, I assume if I buy that oil tomorrow I should be fine for another 2K? Does the BMW engines have dip stick to check oil level? just wondering because I recall reading somewhere that there is none.
12-16-2013, 08:45 PM | #2 |
Rep 31
I have just bought a few Pre-Owned BMW's and it seems that adding oil every 2500 is normal from what i'm reading and it depends on your driving habits. If it starts using a quart in less than 750 then people say it needs to be looked at...just what i have started reading, so maybe someone with more knowledge will chime in.
12-17-2013, 08:07 PM | #3 |
Rep 3,035
Drives: 2022 BMW X5
this morning I called service rep. and sure enough she told me to add 1 quart of oil which I finally did. Now the computer shows oil level at max. Here is my question, if oil was at minimum level and engine takes 7 quarts, by adding 1 quart of oil I should be somewhere in the middle at the best. What is this a malfunctioning of reader or what?
12-18-2013, 12:55 PM | #4 | |
Rep 232
