      03-31-2023, 06:13 PM   #1
Ottopotamus
Drives: 2012 X5 35d
X5 35d Clutched Alternator Pulley Spacer
I was planning on replacing my alternator pulley with a clutched pulley. I was going to buy it from one of the suppliers with the spacer but I had the INA-5350183100 in my cart when I placed an order with FCPEURO. After I realized it, I couldn't cancel the order since it was already in process. I may be able to still return it, but would need to pay return shipping. I asked the suppliers offering the pulley with the spacer if they would sell me just the spacer, but so far no luck.
I was hoping I could just use a washer or washers as a spacer. Is anyone able to post a close up picture of the spacer with dimensions (inside hole size, thickness)?
      04-01-2023, 11:49 AM   #2
RL18
Drives: 2011 335d sport
Might have better luck finding this answer on the “NADBOG” group on Facebook. I have a clutched alternator pulley but I think I was given the setup for a 335d so I didn’t get the spacer, but idk I can’t remember if I did. I’ll try to find it and let you know.
You’d be better off contacting a machine shop or something to make you one.
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R.
      04-01-2023, 06:50 PM   #3
jbash87
2012 BMW X5 35d  [10.00]
2006 BMW M5  [10.00]
The back face of my pulley sits ~1.65mm (.065in) away from the alternator. I'm not sure if that is the exact thickness washer you would need, but at least you can use that to find a washer of the correct thickness at a hardware store. You'll have to measure the shaft to figure out what ID washer you'll need.
I'm pretty sure most washers of this size will be ~.063in thick so that should do you just fine.
      04-03-2023, 02:58 PM   #4
Ottopotamus
Drives: 2012 X5 35d
Thank you for the replies. I did get a response from IDPARTS.COM and placed my order there:
https://www.idparts.com/x5d-clutched...r-p-12236.html
