03-18-2023, 07:17 PM | #1 |
Builder of Special Cars
202
Rep 483
Drives: G12 B7,F02 750li,E70 X5M,E46M3
Location: Dallas, TX | Farmington, UT | Gainesville, FL
Coding for LED Interior Lights
Getting these errors in ISTA+ (see pic)
but dont see the option to convert to LED in BImmerCode either. (see pic of bimmercode saying its an option)..but in doing a pull on my E70 x5M, its not there, anyone else see this? Anyone do this for the X5 E70? |
03-18-2023, 08:24 PM | #2 |
Rep 391
Not sure about bimmercode but you can code out the errors using NcsExpert.
03-18-2023, 10:28 PM | #3 |
Rep 872
I didn’t need to code anything:
https://www.bimmerpost.com/forums/sh...php?p=24393912
2013 X5M AW/Blk
Build Thread: https://www.xbimmers.com/forums/show....php?t=1499820 |
03-20-2023, 01:17 PM | #4 | |
202
Rep 483
Bimmercode said you need to change these values. WARMUE_IB_M1_35 > nicht_aktiv KALTUE_IB_M1_35 > nicht_aktiv to active for both..or you will get the errors in ISTA as i shown in my previous post. |
03-20-2023, 02:30 PM | #5 |
Rep 872
I didn't check ISTA, but I don't show any errors in bimmergeek...
Troy is going to help me get setup in ISTA, I have it, but never used it for coding...always for instructions only. It's possible the bmw tech coded them for me when he saw the errors...he was checking codes last time I dropped it off.
2013 X5M AW/Blk
03-20-2023, 02:33 PM | #6 |
202
Rep 483
I'll bet those errors are there unless he coded them like you said (if he knew where to code them too). I simply replaced mine like you, it doesn't show a check engine but the location where i said, is where you turn on ACTIVE for those two spots to get the errors to go away.
It doesn't show up in other readers, only ISTA+ but i am particular in keeping my ISTA+ error free so dealer doesn't think i am screwing things up or wont touch it. |
